Gen V low oil pressure light at idle and tapping sound under power.
Old Mar 25, 2008 | 05:13 PM
vectorsc's Avatar
Default Gen V low oil pressure light at idle and tapping sound under power.
What do you guys think? At idle, the LOP light comes on after the vehicle is warm and has been driven a little bit. Then, even though the LOP light isn't on at higher RPMS, there is a slight rattle under load. It just started doing this a few hours ago.
I changed the oil to Mobil 1 to see if it would help. BTW, I'm not driving it like this. :-)
What troubleshooting steps would you take, and why? I'm very mechanically adept (suspension swaps, engine rebuilds, electrical), but it has all been targeted at Euro's.
Thanks!
Old Mar 25, 2008 | 05:22 PM
h23troici's Avatar
Default Re: Gen V low oil pressure light at idle and tapping sound under power. (vectorsc)
your oil pump many be going if the oil pressure is low and if it sounds like a marble in the engine then it is a knock. You have to rebuild the engine if the oil pump is not good
Old Mar 25, 2008 | 06:36 PM
vectorsc's Avatar
Default Re: Gen V low oil pressure light at idle and tapping sound under power. (h23troici)
Eeek....well, anyone else want to chime in?
Old Mar 25, 2008 | 07:36 PM
117's Avatar
117
Most likely the beginnings of a spun bearing, especially if it's knocking. The oil pressure light only comes on at a very, very low pressure (around 7 PSI), so there's definitely a problem. The knocking would indicate a problem with a rod bearing. Not certain, but most likely.
Old Mar 26, 2008 | 04:40 AM
vectorsc's Avatar
Default Re: (117)
Would you recommend that I go after just the mains and rods, or do a complete tear down? And can you spin the top shell out of the journal without taking out the CS on a Honda like you can a BMW?
Thanks!
Old Mar 26, 2008 | 02:51 PM
pentaq's Avatar
Default Re: (vectorsc)
I'm afraid you're to pull the crankshaft out to replace top halves of mains as they're locked
Old Mar 26, 2008 | 02:53 PM
117's Avatar
117
If it's knocking, it's likely the crankshaft is already damaged.
Old Mar 26, 2008 | 03:20 PM
vectorsc's Avatar
Default Re: (117)
I'll keep you guys updated as the cookie crumbles. That way, you can see how accurate your guesses were.
Old Mar 31, 2008 | 03:54 PM
vectorsc's Avatar
OKAY...Update! There is NOTHING quite like a HUGE amount of copper colored chips of metal in your oil pan to let you know that U are screwed.
Old Apr 1, 2008 | 04:09 AM
bluedlude's Avatar
ouch, start looking for a new block
Old Apr 1, 2008 | 04:59 AM
vectorsc's Avatar
Default Re: (bluedlude)
Why would I need a new block, out of curiousity? I haven't taken the caps off yet, but I'm interested in your experiences with this type of problem.
I know when this happens in BMW's usually the block is fine.
Old Apr 1, 2008 | 05:32 PM
vectorsc's Avatar
Okay, I need some help now. I have found the problem, and it was the #1 con rod bearing . It did not actually spin. It was coming apart, but I stopped the car before it vaped.
There isn't any scoring on the camshaft, but there is some heat bluing on the con rod. Is it possible to just replace the con rod bearings and the mains and be reliable? Or am I looking at remachining my crank/new rods/pistons?
Head looks fine, and so does the rest. Thanks!
Thanks for your input.
gonzo62
Honda CR-V & Element
Jun 4, 2018 05:57 PM
dorlando
Mar 2, 2017 04:03 AM
s2kkid
May 4, 2010 12:30 AM
sublimenerd
16
Sep 25, 2006 02:33 AM
turboh22chick
Jan 13, 2005 09:09 PM
