Will my '89 a6 tranny work with my newer '95 z6?
Old Mar 25, 2008 | 04:45 PM
Maxcapacity's Avatar
Default Will my '89 a6 tranny work with my newer '95 z6?
Planning on doing a swap soon, picked up a '95 z6 motor,ecu, wiring harness for dirt cheap with no tranny, I want to use my dead a6's tranny..
Will it just bolt on with no issues?, do I need a specific clutch?
Any help appreciated...
Old Mar 25, 2008 | 05:01 PM
nitewolf's Avatar
Default Re: Will my '89 a6 tranny work with my newer '95 z6? (Maxcapacity)
yea it wil work you can use any clutch except the 88
Old Mar 25, 2008 | 05:49 PM
Default Re: Will my '89 a6 tranny work with my newer '95 z6? (nitewolf)
Sweet, Thats what I wanted to hear.
Thanks
Old Mar 25, 2008 | 06:18 PM
schardbody's Avatar
just make sure you match the clutch to the flywheel. for instance if you use the z6 flywheel get a 92-00 clutch. if you use your stock a6 flywheel use stock clutch. if your car is an 88 then you are stuck with the clutch from an 88 and will need to re-use the a6 flywheel.
Old Mar 25, 2008 | 06:54 PM
Default Re: (schardbody)
Thanks alot for more info I did not know about..
pinecone
Jun 22, 2006 05:27 PM
g_rant2006
Feb 6, 2006 08:48 AM
JapJunkie
Dec 1, 2005 06:24 PM
Ecugrad
Apr 11, 2005 11:36 AM
egchan
Oct 6, 2003 01:28 PM
