LS swap... Having fuel problems... I think
Old Mar 25, 2008 | 04:40 PM
nebulabox's Avatar
Default LS swap... Having fuel problems... I think
I have a 94 EG and put an OBD 1 LS in it, and when I started it, I have to keep on the gas to keep it running... I have a Skunk2 intake manifold and NGK spark plugs, but should I do anything to the fuel system for this setup? I also have full exhaust, JDM ITR header, and 2.5 all the way back...
Any suggestions?
Old Mar 25, 2008 | 05:15 PM
GErippenARS's Avatar
Default Re: LS swap... Having fuel problems... I think (nebulabox)
Sounds like a possible issue with the timing of the motor. Did you put a light on it? If so, then could be sensor related.
Mass air flow
TPS
IACV
(all electrical connectors are connected?)
You have a CEL lit?
Old Mar 25, 2008 | 07:51 PM
nebulabox's Avatar
Default Re: LS swap... Having fuel problems... I think (GErippenARS)
Yeah, the only CEL I had was the coolant temp. So I wasn't sure what was going on. And the timing should be right. I haven't put a light to it, but everything else is lining up.
Old Mar 25, 2008 | 08:05 PM
MadScientist305's Avatar
sounds like its some sort of sensor problem. What rpm is your idle at?
Old Mar 25, 2008 | 08:42 PM
afstvx's Avatar
sounds like a tps sensor possibly... did the ls motor run before you got it... or did you get it from some shaddy motorplace.
Old Mar 26, 2008 | 02:00 PM
nebulabox's Avatar
Default Re: (afstvx)
I got the motor from H-motors online. It's the third one I have bought from them, never had a problem. The motor, doesn't idle. I have to keep on the gas a bit to keep the car running.
Old Mar 26, 2008 | 03:18 PM
faxshatch's Avatar
Default Re: (nebulabox)
My geuss would be in ur feul system to. Maybe check ur injectors rail and feul pump. Maybe sumthins clogged up really good???
pink94coupe
Jun 23, 2011 06:11 PM
91blackEF
Apr 24, 2010 03:46 AM
94-integra-ls
Feb 3, 2009 09:16 AM
RacinMasonC
May 28, 2008 09:21 PM
timm099
Apr 9, 2007 12:19 PM
