Parts Needed for D16Z6 into DPFI CRX
Old Mar 25, 2008 | 02:38 PM
GI8U2racing's Avatar
Default Parts Needed for D16Z6 into DPFI CRX
I have seen many threads about what is needed for the D16Z6 swap into a CRX Si, but I was wondering about an 89 Civic Std. My friend is having some rod knock, and would like to upgrade to 5 spd with a little more power. I know we need:
-D16Z6 longblock with VTEC solenoid and pressure sensor off 92-95 Civic EX or Si
-Tranny off 92-95 Civic EX or Si
-P28 ECU
-OBD0->OBD1 harness
-Some sort of DPFI->MPFI harness
I am not sure about:
-Engine mounts
-Header-back exhaust lining up
-Airbox intake piping lining up
-Other wiring needed
-Axles
Can anyone at least begin to define the parts we will need for this swap?
Old Mar 25, 2008 | 03:22 PM
Ermil's Avatar
Default Re: Parts Needed for D16Z6 into DPFI CRX (GI8U2racing)
u rs surch maztr
Old Mar 25, 2008 | 05:17 PM
Default Re: Parts Needed for D16Z6 into DPFI CRX (Ermil)
Thanks Emril for all your help
for future reference, I found this by the way:
http://www.angelfire.com/d20/h....html
Old Mar 25, 2008 | 05:24 PM
crxricer66's Avatar
go to the members list up top of the screen, and type in monotech. he does mpfi swap harness plus obd1 and all you need. its 150 bucks for mpfi swap harness, which i jus got mine and its awesome..... definetly worth every penny. talk to him hes the man
Old Mar 25, 2008 | 06:27 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">I have seen many threads about what is needed for the D16Z6 swap into a CRX Si, but I was wondering about an 89 Civic Std. My friend is having some rod knock, and would like to upgrade to 5 spd with a little more power. I know we need:
-P28 ECU
-OBD0-&gt;OBD1 harness
-Some sort of DPFI-&gt;MPFI harness
-Engine mounts
-Axles
Can anyone at least begin to define the parts we will need for this swap?</TD></TR></TABLE>
keep your stock mounts, and re-use the drivers side bracket off the stock motor, you will have to trim the lower timing cover for it to fit but it puts the engine more square in the bay.
the z6 transmission wont work unless you get some VERY expensive hasport mounts. not worth it, keep the stock transmission or upgrade to a cable SI trans
stock axles
need a mpfi throttle cable
use exhaust manifold and downpipe or header for the z6, it will bolt to the stock exhaust of your car
not sure about intake lining up, i use aftermarket so doesnt matter
4 wire oxygen sensor and wiring
other than the conversion from dpfi and obd1 you should be good.
Farfromfame
Oct 11, 2013 08:20 AM
chafetzk
Aug 10, 2010 08:32 AM
Amf_crx
Mar 20, 2004 02:52 PM
craigie
Apr 28, 2003 08:45 PM
