car wont rev past 6800k. any ideas
Old Mar 25, 2008 | 01:52 PM
boosted92hatch's Avatar
Default car wont rev past 6800k. any ideas
my car wont rev past 6800 but supposed to be 8200. any ideas. revs to 8200 if there is no load on engine(example: when clutch is in it will go to 8200) no CEL light on so its not a sensor
Old Mar 25, 2008 | 02:00 PM
GuNnErGoD's Avatar
Default Re: car wont rev past 6800k. any ideas (boosted92hatch)
We need some more information on the subject..
What motor is it? Is it boosted?
Old Mar 25, 2008 | 02:01 PM
Default Re: car wont rev past 6800k. any ideas (GuNnErGoD)
no its not boosted and its a h22.
Old Mar 25, 2008 | 02:04 PM
h22 civic. p28 ecu. engine is fine. no check engine light. just stopped redlineing at 8200 and will only go to 6800. couple people said ignition issue, plugs wires cap and rotor, can it be something along those lines
Old Mar 25, 2008 | 02:14 PM
MassScene's Avatar
since it only happends under load I would go with something ignition,, (distributor, coil, igniter) or map sensor related.
Old Mar 25, 2008 | 03:44 PM
B16b-EJ8's Avatar
Default Re: (MassScene)
Check your oil
Old Mar 26, 2008 | 01:27 AM
dont know but i change the plugs and dizzy rotor and problem solved. thanks for the advice
Old Mar 26, 2008 | 10:31 AM
MassScene's Avatar
Default Re: (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Check your oil</TD></TR></TABLE> didint even think of that and it has personally happened to me.
Old Mar 27, 2008 | 08:34 PM
FRANKIESPEED's Avatar
Default Re: (boosted92hatch)
she runs great stop f.....g wit it ! great pull and all picky puta!
Old Mar 27, 2008 | 08:36 PM
SirRevvs's Avatar
Default Re: (FRANKIESPEED)
Make sure you run H22 injectors too and hopefully you have a map for a H22 on that P28. Get that **** tunzered!!
Old Mar 27, 2008 | 08:57 PM
EJcivicJDM7's Avatar
Your redlining an H22 at 8200? Is it a decent build?
Old Mar 27, 2008 | 09:00 PM
SirRevvs's Avatar
Default Re: (EJcivicJDM7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcivicJDM7 &raquo;</TD></TR><TR><TD CLASS="quote">Your redlining an H22 at 8200? Is it a decent build?</TD></TR></TABLE>
My buddy has a H22A4 in his 93 accord with a tuned p28 and type-s cams. He does 8200 every day and hasn't had any problems. He also isn't using his balancer shafts.
Old Mar 27, 2008 | 11:36 PM
wudini's Avatar
Default Re: (SirRevvs)
i doubt there's any power gain at 8200. 7200RPM is stock redline, 7800 is stock fuel cutoff. unless you have a built head i'd stay shifting before or at 7200.
Old Mar 29, 2008 | 09:34 PM
Default Re: (wudini)
yes its a h22 map and injectors, and a h22 makes its pow er peak at 6800 so i dont see why i would shift at 7200!! maybe 7800. it is already tuned and the car started screwing up again so i looked closer and someone cut the yellow and black wire on the map plug so it was just getting enough to not throw the cell then i dumped the clutch and it threw a cell. code 3. MAP. so i soldered in a new plug. right back to 8200. thanks for all the help. oh and frankiespeed, what we see as running good is 2 totally different things.
EKCb16a2
Nov 11, 2015 07:10 PM
boush95ls
Apr 11, 2008 09:47 PM
eonblue22
Dec 11, 2007 05:28 PM
Damon Reeves
Jul 9, 2007 11:20 AM
SAVIOVEGA
Jan 15, 2004 07:13 AM
