Has anyone ever Lost power after doing a valve adjustment?
Old Mar 25, 2008 | 12:17 PM
LastGenEK's Avatar
Default Has anyone ever Lost power after doing a valve adjustment?
I Did a valve adjustment on my Civic last week and it feels and sounds different. Right away I noticed My Mid Range and Top end Have lost power noticeably.
Intake was lashed at .006 and exhaust is at .007
Setup:
B18C With stock head
Wisco 8.8 to 9.1 comp
Scat H-Beams
Head-studs
blah,blah blah
Freshly built 1,200 miles ago not yet boosted
I would like to know if anyone has experinced this or am I amagining this?
Old Mar 25, 2008 | 12:47 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Has anyone ever Lost power after doing a valve adjustment? (LastGenEK)
you probably did the valve lash incorrectly and have them too loose, are they loud? or are the valves quiet and make the car hard to idle?
Old Mar 25, 2008 | 01:05 PM
LastGenEK's Avatar
Default Re: Has anyone ever Lost power after doing a valve adjustment? (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">you probably did the valve lash incorrectly and have them too loose, are they loud? or are the valves quiet and make the car hard to idle?</TD></TR></TABLE>
When i did them I actually did them tight and it did quiet them down, They're not noisiey. and it idels normal.
My Low end torque is the same but *** soon as it gets to 4,500rpm there is no power, and i know the low comp isnt helping any but it ran Sooo good before i did the valve adjustment.
Old Mar 25, 2008 | 01:10 PM
Max500's Avatar
how do you know you are loosing power? Butt dyno?
Old Mar 25, 2008 | 01:53 PM
i would redo them, it sounds like they may be on the tight side
Old Mar 25, 2008 | 02:40 PM
Jared's Avatar
Three possibilities:
1. You did the valve adjustment incorrectly
2. It's in your head
3. They were tight before which "simulates" more camshaft and the engine wants more cam
Old Mar 25, 2008 | 03:08 PM
ExospeedAMcrx's Avatar
stock cam?
Old Mar 25, 2008 | 06:47 PM
LastGenEK's Avatar
Default Re: Has anyone ever Lost power after doing a valve adjustment? (ExospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">i would redo them, it sounds like they may be on the tight side</TD></TR></TABLE>
I Think i will redo them! intake at .006 and exhaust at .008
Ill do them not so tight<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Three possibilities:
3. They were tight before which "simulates" more camshaft and the engine wants more cam</TD></TR></TABLE>
Stock cam
Old Mar 27, 2008 | 06:21 AM
LastGenEK's Avatar
Default Re: (Jared)
I dont really understand this. What do you mean by "The engine wants more cam"?
Since I lashed them tight can it cause my problem?
Old Mar 27, 2008 | 07:36 AM
laocivic's Avatar
Default Re: (LastGenEK)
well u did break in ur motor right? mayb the motor feels different after the rings seat
Old Mar 27, 2008 | 11:25 AM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">
Since I lashed them tight can it cause my problem?</TD></TR></TABLE>
What he is saying is the tigher the lash, the closer the rocker gets to the cam. This allows the valve to open more.
Old Mar 27, 2008 | 11:32 AM
BB6loveBOOST's Avatar
well if you do it wrong you'll lose power...
Old Mar 27, 2008 | 02:51 PM
LastGenEK's Avatar
Default Re: (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">
What he is saying is the tigher the lash, the closer the rocker gets to the cam. This allows the valve to open more.</TD></TR></TABLE>
Should i redo them and to what lash
if i redo them should i do them tighter or could they be too tight?
Old Mar 27, 2008 | 03:08 PM
Jared's Avatar
if i redo them should i do them tighter or could they be too tight?</TD></TR></TABLE>
were they loose or tight before the adjustment?
Old Mar 27, 2008 | 07:20 PM
LastGenEK's Avatar
Default Re: (Jared)
were they loose or tight before the adjustment?</TD></TR></TABLE>
They seemed tight.
Well i relashed the gaps
Intake at .006
Exhaust at .008
Ill let you know after driving it
Old Mar 29, 2008 | 07:38 AM
LastGenEK's Avatar
Well it seems to run better with the exhaust a little bigger lash. I might re-lash the intake to .007 and see how that runs
Old Mar 29, 2008 | 10:09 AM
HAMOTORSPORTS's Avatar
Since you are running low compression, if you add duration/lift ( tight lash) you will loose even more dynamic compression . . . could be making the sluggish motor even worse
Old Mar 29, 2008 | 02:27 PM
LastGenEK's Avatar
Default Re: (HAMOTORSPORTSUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA &raquo;</TD></TR><TR><TD CLASS="quote">Since you are running low compression, if you add duration/lift ( tight lash) you will loose even more dynamic compression . . . could be making the sluggish motor even worse </TD></TR></TABLE>
Thank You I was hoping someone would say that. Thank you all for your help
Old Apr 3, 2008 | 11:09 PM
LastGenEK's Avatar
I Just replaced my stock cat Today ANd all the power i lost is back. So if anyone reads this I was struggleing for my power loss and days of troubleshooting and it was all my cat
krazeenoy
Apr 6, 2007 12:49 AM
92ehatch
Feb 3, 2006 10:47 AM
BLK99VTECR
Mar 1, 2004 05:13 AM
wig
May 3, 2002 05:35 AM
HX_Guy
Nov 7, 2001 08:39 AM
