new to accords...... (not new to hondas)
Old Mar 25, 2008 | 09:36 AM
swainsol's Avatar
Default new to accords...... (not new to hondas)
ok i am thing about buying a 4 door accord for my next little project. But i like the 4th generation and 5th generation not sure of the chassi codes.sorry. But i just wanna know whateveryone thinks about the two, the pros and cons of both, parts avalabilty and so on. ill be dropping an h22 in either one of them. so any help and comments would be greatly appreciated.
i have had a 95 civic h22 swapped
and now a 94 4dr gsr with jdm front
so im not completly stupid just stupid with accords
Modified by swainsol at 10:44 AM 3/25/2008
Old Mar 25, 2008 | 12:06 PM
96_Accord_lx's Avatar
Almost all the parts on the 5th and 4th gen accords are interchangeable so theres no problem there and the H22 will for sure line right up in the 4th gen accord not too sure about the 5th gen though!
Old Mar 25, 2008 | 12:46 PM
TASAuto.com's Avatar
Banned
Default Re: (96_Accord_lx)
4th gen accord - chassis code CB
5th gen accord - chassis code CD
Both work nicely with an H22 swap
More parts are available for 94-97 than the old ones but both have tons of aftermarket support.
I would go by mileage and condition and worry less about the year.
Keep an eye out for rear quarter rust while shopping around as these cars are known for problems in that area.
Any other questions?
Old Mar 25, 2008 | 01:06 PM
swainsol's Avatar
ive seen quite a few pictures of both the CB and CD's with jdm headlights fogs tail lights grills and stuff like that where are some sites that sell this stuff
Old Mar 25, 2008 | 03:54 PM
erk89's Avatar
Default Re: (swainsol)
^tasauto.com is pretty much the ****^
Old Mar 25, 2008 | 07:27 PM
tpot90's Avatar
Default Re: (erk89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96_Accord_lx &raquo;</TD></TR><TR><TD CLASS="quote">Almost all the parts on the 5th and 4th gen accords are interchangeable so theres no problem there and the H22 will for sure line right up in the 4th gen accord not too sure about the 5th gen though!</TD></TR></TABLE>
Doesnt the H22 come with the 5th gens? I thought it did, i could be wrong..
Old Mar 25, 2008 | 08:05 PM
Well if im correct then the 4th gen accord is the 94-97 which is an F22 but now that i think about it im pretty sure that the 5th generation in the 94-97 either way those years are F22's not so sure that the newer ones come with H22's but again i could be wrong...
Old Mar 25, 2008 | 09:09 PM
Honda_Accord's Avatar
5th gens are 94-97 and no the h22's are in none of the accords (other then the accord SIR and the accord euros-r) h22's were in the preludes, 4th and 5th gens have the f22's as well as i believe the 6th gens.. not to familar with 6th gens
Modified by Honda_Accord at 12:15 AM 3/26/2008
Modified by Honda_Accord at 12:28 AM 3/26/2008
Old Mar 25, 2008 | 10:52 PM
talontsiawd's Avatar
Default Re: (Honda_Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Accord &raquo;</TD></TR><TR><TD CLASS="quote">5th gens are 94-97 and no the h22's are in none of the accords (other then the accord SIR and the accord euros-r) h22's were in the preludes, 4th and 5th gens have the f22's as well as i believe the 6th gens.. not to familar with 6th gens
4th gens-f22's
5th gens-f22's
6th gens-f23's
I've owned them all lol. The advantage of going older is that you can more easily find a legal engine (well that depends on where you live) as states such as cali require the engine to be the same year or newer than the car. So if you had a 97 accord, you could only get an h22 from a 97-01 prelude. That's in cali atleast.
Old Mar 26, 2008 | 12:23 AM
JayDeeEmm's Avatar
h22 = preludes
Old Mar 26, 2008 | 01:51 AM
Derek128's Avatar
Default Re: new to accords...... (swainsol)
CD accord comes w/ h22 in Asia (also named Accord SIR)
there are 4Dr, 2Dr & 5Dr wagon SIR
other than f22 & h22
U can also drop
F20b (from JDM 6 gen accord SIR or SIR-T)
* Bore × Stroke: 85.0 × 88.0 mm
* Displacement: 1997 cc
* Valve Configuration: DOHC, 16 valves, VTEC
* Compression ratio: 11.0:1
* Max power: 180PS (auto)-200PS (manual) (134-149 kW) @ 7000 rpm
* Max torque: 141-144 ft·lbf (189 N m) @ 5500 rpm
F22 (from JDM 5gen accord DOHC non-vtec similar to the H23a1)
* Bore × Stroke: 85.0 × 95.0 mm
* Displacement: 2156 cc
* Compression ratio: 9.3:1
* Max power: 160 hp (119 kW) @ 6000 rpm
* Max torque: 148 ft·lbf (200 N m) @ 5000 rpm
H23a1 (from USDM 4gen prelude, DOHC non-vtec)
# Bore x Stroke: 87.0 x 95.0 mm (3.74 in)
# Displacement: 2258 cc (138 cu. in.)
# Valve Configuration: DOHC, 16 valves
# Type: In-line 4 cylinder, aluminum block and head
# Compression ratio: 9.8:1
# Max power: 160 hp (119 kW)
# Max torque: 163ft·lbf (207 Nm)
# Redline: 6500 rpm
H23a (from JDM 6gen accord wagon, DOHC Vtec)
* Compression ratio: 10.6:1
* Max output : 200 PS (197 hp/147 kW) @ 6800 rpm
* Max torque : 220 N·m (160 ft·lbf) @ 5300 rpm
* Redline: 7200 rpm
Old Mar 26, 2008 | 10:47 AM
JayDeeEmm's Avatar
H23 FTW!
Old Mar 26, 2008 | 01:58 PM
swainsol's Avatar
anyone else have any sites for jdm accord parts?
Old Mar 26, 2008 | 02:00 PM
TheMuffinMan's Avatar
He knows where you live!
the same places you'd buy jdm parts for every other car?
ebay, pwjdm, etc
Old Mar 27, 2008 | 10:42 AM
JayDeeEmm's Avatar
ICB motorsports
http://www.jdmland.com
eavtimmy
Jun 23, 2005 11:06 AM
JonnySBeee...
Apr 18, 2005 08:51 AM
blackcd
Jan 11, 2003 07:52 PM
ExAcc
Sep 19, 2002 09:44 PM
TouringAccord
Aug 8, 2002 04:15 AM
