how much can you boost on stock 94 ls motor b18
Old Mar 25, 2008 | 07:59 AM
Andy Hatchback's Avatar
Default how much can you boost on stock 94 ls motor b18
like no head work or block sense it is non v tec low compression. just wondering how many pounds of boost can you push it without throwing anything?
Old Mar 25, 2008 | 08:01 AM
rick1574's Avatar
1-30lbs
Old Mar 25, 2008 | 08:03 AM
Luserkid's Avatar
Default Re: how much can you boost on stock 94 ls motor b18 (Andy Hatchback)
Enough to make 300whp, pushing it.
Old Mar 25, 2008 | 08:39 AM
Paulie Pesos's Avatar
Ive been running 10 psi on mine for a year with no problems....in my mind no higher than 10 is perfect with good power, and safe for the engine.
Old Mar 25, 2008 | 09:00 AM
Jakester9500's Avatar
my one buddy is running, I think 11 on his b18. makes 268 whp, I know that. been that way for almost a year...
Old Mar 25, 2008 | 09:37 AM
egjdmcivichatch's Avatar
Default Re: (Jakester9500)
are these cars tuned or untuned?
Old Mar 25, 2008 | 11:30 AM
afstvx's Avatar
would a stock b20 be able to make the boost numbers too...reliably?
Old Mar 25, 2008 | 12:15 PM
v8killaz's Avatar
Default Re: (egjdmcivichatch)
of course their tuned
Old Mar 25, 2008 | 12:22 PM
Schister66's Avatar
Man U FTW
If we're going to have a discussion here, please post relevant, informative information.
First of all, boost doesn't really determine anything (until you get to the point where spiking IATs become a factor OR you're running a stock map and can't boost more than 11psi). Other than those two instances, boost pressure is not an indication.
Power is what you should base your goals from. Most stock B series engines are good for about 300whp at whatever PSI you need to get them there (other than the factors i listed above). If we're going to have a discussion about this, at least use correct information in your posting.
By the way, forced induction posts are generally answered better in the Forced Induction forum...
GSR_Hatch711
Feb 3, 2009 07:01 PM
JDM_Acccord
Jul 5, 2007 03:24 AM
JUANSTURBOTEG
May 18, 2007 06:43 PM
broadheadjohn
Apr 15, 2007 11:48 AM
mybarra
Apr 2, 2004 12:28 AM
