HP loss with install of springs/retainers
Old Jul 9, 2002 | 10:26 AM
Mover's Avatar
Default HP loss with install of springs/retainers
I've installed a set of Crower springs/ti retainers along with the 'stock' cam
in my 94 Prelude VTEC. (Don't ask me why I put back the stock cam)
Has anyone actually measured a hp loss with the install of stiffer valve springs ?
The motor doesn't seem to pull as strong in the higher end as it used to with the stock (weaker) springs. The cams and crank are all lined up correctly
Old Jul 9, 2002 | 03:25 PM
non-VTEC's Avatar
Default Re: HP loss with install of springs/retainers (Mover)
there probably would be a "slight" loss since there is more drag on the valve train now.........but you should upgrade your cams. they will make up for the slight power loss.......
Old Jul 9, 2002 | 04:00 PM
Mover's Avatar
Default Re: HP loss with install of springs/retainers (non-VTEC)
What do you consider to be a 'quality' upgrade with all the stories that are going around ?
Old Jul 9, 2002 | 04:06 PM
non-VTEC's Avatar
since you have the complete crower valve train why not go with crower H22A VTEC cams............
Old Jul 11, 2002 | 03:24 PM
Mover's Avatar
he is out of blanks at the moment
bigboy56
11
Sep 20, 2012 02:35 PM
406Honda
Aug 23, 2010 12:25 PM
pythoner
Sep 29, 2007 03:45 PM
CRXSleeper
Sep 9, 2002 10:47 PM
Black R
Jun 15, 2001 06:58 AM
