VAFC throttle setting detection...
Old Jul 9, 2002 | 10:26 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default VAFC throttle setting detection...
hey guys. i set up my VAFC and did the 10-second on, 10-second off throttle calibration when the car was off. sensor check indicates i have somewhere aroudn ~.45 volts closed, and 4.6V at WOT. however when I start my car, my closed goes down to ~.25 volts. i'm assuming this is because i have a different throttle body. however because of this, the calibration is off and it think i'm stillat 0% throttle when i'm lightly pressing the pedal. it does get annoying because the throttle reading is off now. is there any way i can calibrate it to the right setting while the car is on? i wouldn't really want to try holding it at WOT for 10 seconds when it's on, though
Old Jul 9, 2002 | 01:30 PM
Default Re: VAFC throttle setting detection... (dLo GSR)
ttt
Old Jul 9, 2002 | 07:36 PM
speedymon's Avatar
shouldn't the reading stay the same when the car is started? Why would the tps voltage change?
Old Jul 9, 2002 | 07:42 PM
disordeR's Avatar
Default Re: VAFC throttle setting detection... (speedymon)
word
Old Jul 9, 2002 | 09:31 PM
beats me. but it does.
Old Jul 10, 2002 | 12:57 AM
kinesistech's Avatar
Usually the values increase with the car running because the alternator is charging. So if I were you I would check output voltage on the alternator, just to make sure. Then I would check the wiring for the vacf.
smkngsr
Mar 22, 2005 10:40 PM
NAturalDC2
Mar 30, 2004 04:01 PM
cjames235
Dec 11, 2003 12:39 PM
Hybrid 350GT
Jan 7, 2003 01:16 PM
IgniteTeg
Aug 9, 2002 07:25 PM
