Thnak You Thank You Thank You :)
Old Mar 25, 2008 | 02:09 AM
Singnakornchai's Avatar
Default Thnak You Thank You Thank You :)
All,
For all those that have helped me resolve my idle problem on my 98 civic 5 door hatch vti.
Summary.
Was reving at 1500, running rich, hunting when warm at 2500 - 3500, throwing no error codes.
I replaced he throttle body "did not work"
Cleaned out IAC "did not work"
Replaced various sensors "did not work"
OK so I took to Honda to get them to check, they said "your ECS is not reading above 50c, that COULD be your problem". In fairness they were great if not a little slow to look at my car. They wanted around 250 to replace this sensor plus temp sensor and re-fill coolant, clean throttle body etc" they also said "this may not solve the problem"
I therefore went and got a used sensor from the scrap yard "ECS" as soon as I replaced it, problem solved
So there we go. Again thanks everyone for your advice and help over the last month
TK_209
Oct 11, 2009 05:21 PM
dolbo74
Sep 14, 2008 03:35 PM
nick1981
Apr 7, 2007 04:33 PM
98gsrTEG
Apr 17, 2004 11:12 AM
prendi
17
Apr 29, 2003 07:38 AM
