cr-v-tech's garage $ale!!!!
d167y dizzy minus coil, great condition $30.00
98' f23vtec alternator $40.00
JDM h22 type-s upper header(have heat shield also) scrapped
usdm h23a stock manifold w/heat shields $sold
usdm 97'-01' auto intermediate shaft scrapped
Modified by CR-V-tech at 7:59 PM 3/26/2008
Modified by CR-V-tech at 12:13 AM 6/19/2008
continued
98 h22 p/s pump and bracket scrapped
93' h23a a/c compressor $sold
98' f23vtec p/s pump $30.00
Modified by CR-V-tech at 9:23 AM 3/25/2008
Modified by CR-V-tech at 8:01 PM 3/26/2008
Modified by CR-V-tech at 12:14 AM 6/19/2008
continued again
97'-01' h22 dr side mount bracket scrapped
98 f23vtec long block $250.00 (in great working order!)
97'-01' h22 auto flex plate scrapped
98' jdm h22 type s a/c comp bracket $20.00
93 h23a resistor box $20.00
03' k-series tps (actually off a d17, but believe they interchange!)$20.00
usdm obd2b h22a ecu p5m $80.00
usdm obd2a f23vtec ecu paa $40.00
obd0 pm8 ecu $30.00
jdm type s fuel rail scrapped
d-series "hf" manifold $30.00
93' lude si 5spd trans $200.00
93' lude si h23a long block $old
chrysler 2.7 individual coil packs $60.00
jdm obd0 b16a dizzy $60.00
obd1 p14 ecu $100.00
pm me if you have any Q's, thanks!
Modified by CR-V-tech at 9:26 AM 3/25/2008
Modified by CR-V-tech at 8:02 PM 3/26/2008
Modified by CR-V-tech at 12:16 AM 6/19/2008
obd0 pm8 ecu $30.00
cause i smoke crack joe rogan!!!!!!!!!!!!!!!!!!
