wheel bearing or hub/spindle problem?
Old Mar 24, 2008 | 08:49 PM
RTW DC2R's Avatar
Default wheel bearing or hub/spindle problem?
took off a wheel and axle today and noticed my rotor felt loose. at first I thought it was just the rotor screw but thats not it. the whole rotor and hub feels loose. even when I put the wheel back on, I can shake it. how do I know if its a bearing problem or hub/spindle problem?
Old Mar 24, 2008 | 08:55 PM
ITR.#1446's Avatar
Default Re: wheel bearing or hub/spindle problem? (RTW DC2R)
hey ryan its your wheel bearing when i pulled my motor i checked mine and noticed i had a ton of play on my drivers side, i was actually shocked at how much play it had but still drove fine.
Old Mar 24, 2008 | 09:01 PM
Bbasso's Avatar
your POS is worse then my POS, at least my wheels are not falling off
replace wheel bearings
Old Mar 24, 2008 | 09:06 PM
RTW DC2R's Avatar
on thing after another i swear....ill give the bearings a shot i guess.
Old Mar 25, 2008 | 05:24 AM
citrus3000psi's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">on thing after another i swear....ill give the bearings a shot i guess. </TD></TR></TABLE>
Just making sure that everybody knows when you bang on the knunkle assembly with anything withOUT the axle nut secured you have a risk of damaging the bearing.
I did this 2 months ago on my new daily. I took the axle nuts off with the wheels on the ground (Didn't have a spare person by to hold the brakes down, and didn't have air tools). So all is well but the wheel wont come off, f'n rust. So I gave it a few whacks and it comes off. But after putting everything back together the bearing is bad.
I'm not implying that you did this just putting some info out.
Old Mar 25, 2008 | 05:43 AM
totsie7944's Avatar
Default Re: (citrus3000psi)
Good info man! I don't think many people know that. I'm super glad I didnt' decide to start doing that now when I took out my axles...
Old Mar 25, 2008 | 05:28 PM
itrdave's Avatar
Default Re: (totsie7944)
Your hub might also be bad if you are hearing any noise, but hopefully you can avoid this extra $100 expense...
Another warning - make sure whoever installs the bearing does so by PROPERLY supporting the races such that they don't put press loads across the ***** - this will cause your new bearing to go bad in short order. Ask me how I know !!!
Good luck.
Old Mar 25, 2008 | 05:36 PM
R.Kelley's Avatar
Default Re: (itrdave)
like every body already said...wheel bearing. inspect the hub really good when you have it apart
I was working on a 1.8t Golf today that the customer was complaining about a grinding noise....yea usually bearing will hum a bit. his was straight up grinding, I was surprised the wheel didnt fall off. did both bearings and that one hub
Old Mar 25, 2008 | 06:06 PM
RTW DC2R's Avatar
done, and done. picked up some new bearings, did both right and left sides at my bro's shop
but I lied this was actually on my civic but I plan to do it on my R soon too and now I know how to do it.
Old Mar 25, 2008 | 06:10 PM
R.Kelley's Avatar
its mad easy broski...we charge 2.5hrs a side plus .5 for diag...so 5.5hrs for a 1.5hr job
civic-steve-94
Aug 15, 2015 03:03 PM
alexb18c1
Sep 24, 2008 05:25 PM
ketchup
17
Jun 27, 2008 09:02 PM
B18c1_turbo
Mar 14, 2008 10:43 AM
SomeDude56
Oct 30, 2006 10:49 AM
