Ek civic H22 swap info. Some questions need answers.
Old Mar 24, 2008 | 07:29 PM
puredreamz's Avatar
Default Ek civic H22 swap info. Some questions need answers.
RESISTOR PACK.
- comes with one plug where does the other end of the plug come from and where does it go.
- There was a write up on honda tech about a resistor pack with 14pins the h22 one that i grabbed has 6 pins.
WIRING HARNESS
- i jumped the gun and ordered a odb2b to obd1 jumper harness. I ve an LX (no vtec). I was thinking of grabbing like a 99 Si Wiring harness good idea or bad idea.
Was gonna grab the 98 EX but...then i would need the obd2a to obd1 jumper harness right.
REWIRE DISTRIBUTOR
can someone fully explain this or some me i tried searching on other posts but the pics where moved to iserve and i ve found iserve but no pics.
FUEL LINE
- I know factory civic one doesnt work and some say even the prelude doesnt work has to be 90-93 accord. But i was wondering on ebay they got ss braided fuel lines for civics pre-made with banjo fittings on the ends can anyone confirm if they will work
Old Mar 25, 2008 | 01:31 AM
86elco's Avatar
Default Re: Ek civic H22 swap info. Some questions need answers. (puredreamz)
The resistor pack is straight wired in on my injectors with no conector,, not sure exactly how since someone did it for me,,,, Wiring harnes i believe you could just add the vtec wires and pin them in the approrpiate spot on the harness,,, the dizzy you can by a jumper harness for,, alot easier but they cost around 50-75 dollars,, not sure about the fuel lines i just bought the braided line and fittings and made my own
Old Mar 25, 2008 | 06:24 AM
puredreamz's Avatar
Default Re: Ek civic H22 swap info. Some questions need answers. (86elco)
straight wired how... I m assuming the 4 blacks are 1 for each injector and the red is a 12v switched.
But even straight how would u do that.
Old May 25, 2009 | 01:21 AM
95dsfreakjason's Avatar
the correct distributor if your using the civic harness is a td-60u. it has prelude mounts and an internal coil.
CtotheODY
Mar 16, 2026 08:25 AM
squarepusher
May 6, 2007 04:12 PM
mikegeezy
Mar 13, 2006 08:18 AM
Mini-mEK4
Jan 23, 2005 09:17 AM
Jago
Sep 26, 2003 03:58 PM
