Speedometer issue - need some help
I recently got my alarm installed and after it was done, my speedometer stopped working. I cant see what rpm i'm at, how fast im going, and if i have gas at all. The shop checked everything they did to make sure they didnt screw up and apparently they "didnt".
Anyways, i just want this thing fixed. I already checked the fuses and they're good. It's a 99 civic si with a b18c. It was fine til the shop was done with the installation.
Also, the shop is called Ck Auto Image in Philadelphia just to WARN you guys.
If you guys have any idea to why it maybe not working, please let me know. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">If the odometer and tripmeter also don't work, then you may need to replace the vehicle speed sensor. First double check that fuse 15 isn't blown.</TD></TR></TABLE>
Thanks, ill do that tomorrow.
I dont know where it is cause in the stickies the diagram isnt there. It says "coming soon" and a technician said it probably isnt that. Anyone know what else i should check?
krazieV
Aug 7, 2008 08:43 PM
AErrorist
Oct 15, 2006 04:47 PM
d_mina
May 6, 2004 06:21 AM
