How to wire a Vtec light. for OBD1 ( the correct way)
ok here is what happened i had looked arround a few forums lately to wire up my vtec light. ok well here it is...
Materials needed:
1. LED of your choice 1 pc
2. Gauge 22 or thinner wire 4 meters
3. Electrical tape
Procedure:
Mount the LED where you think it is most visible. i put mine in my cluster with one of the free spaces.
Connect the negative pin to the ground to the negative screw ont eh back of the cluster
you can take the positive wire and put it on the constant power plug on your fuse box.
Now there are two ways in order to tap on to the vtec line.
You can tap directly to the ECU. the third plug Orange wire with the white stripe i did this one so i wouldnt have to go through the fire wall. to me this was much faster
Or you can Tap directly to the vtec solenoid socket! All you have to do is route the wire from the LED to the engine...
Materials needed:
3. Electrical tape
Procedure:
nice writeup, but im not sure why you need a vtec light. I drive a EM1 and i dont have a light, but i can tell you when it kicks in. To each his own i guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKstacy »</TD></TR><TR><TD CLASS="quote">nice writeup, but im not sure why you need a vtec light. I drive a EM1 and i dont have a light, but i can tell you when it kicks in. To each his own i guess.
Ya same here. I had one abck in the day when i had a sohc d15b vtec. Now that im b16 i dont need the light anymore you can deff. hear the crosover to vtec, but nice write up.
</TD></TR></TABLE>Ya same here. I had one abck in the day when i had a sohc d15b vtec. Now that im b16 i dont need the light anymore you can deff. hear the crosover to vtec, but nice write up.
krysted9354
Nov 20, 2008 11:33 AM
JDM 007
Jul 24, 2003 08:29 AM
AsnRefugee
Oct 2, 2002 03:17 AM
All you have to do is run a wire from the solenoid and ground it.
