Calling All users of NGK wide band OR PLX-M300 Click here
Old Mar 24, 2008 | 05:02 PM
2001B18C1GS-R's Avatar
Default Calling All users of NGK wide band OR PLX-M300 Click here
Calling All users of NGK wide band OR PLX-M300.... just having some issues with which one i should get and also would like to here some comments and see on installed pics
im trying to see which one will fit on my steering column if anyone has any pics or comments about these two wide band it would be much appreciated ...thanks
Heres link to both of them
PLX Devices M-300 Wideband
http://www.horsepowerfreaks.co...M-300
NGK AFX WIDEBAND
https://honda-tech.com/zerothread?id=2132965
Old Mar 24, 2008 | 05:33 PM
urbansi's Avatar
Default Re: Calling All users of NGK wide band OR PLX-M300 Click here (2001B18C1GS-R)
before i "borrowed" my PLX to my buddy i had it snug behind my steering wheel on my 99si, dont have any pictures but i am sure that you get the idea.
Personally i thought and my buddy that still has it is that the PLX unit is a little cheap looking and feeling. I would look more into the gauge type WB02's like the AEM or even the FAST unit. JMO
Old Mar 24, 2008 | 05:47 PM
93turbo16's Avatar
I have been using the PLX units for about 4 years now. They are perfect if you are going to keep it in your car for a time and they have a MUCH faster response rate than the NGK unit.
I would much rather use the PLX than the NGK.
Old Mar 24, 2008 | 05:58 PM
SpoolnG2's Avatar
Default Re: (93turbo16)
Been using PLX for a while too and have nothing but good luck with it as well. I originally used the M300 and now i'm using the PLX DM-5 & AFR Wideband o2 which is a PLX gauge style setup. Either one of those would be great IMO.
Old Mar 24, 2008 | 06:07 PM
zex_cool's Avatar
i've also been using the plx m300 for some time now without any issues. it reacts very fast, which took some time getting use to.
i dont have any pics of it but i do have a short dyno vid. where you see how its set up in my coupe.
http://www.youtube.com/watch?v=jlRJn8LjWrE
no install pics but make sure you get a "good" 12v signal and its own ground. the less interference the better, or so i've read.
Old Mar 24, 2008 | 08:12 PM
SPOOLINmatt's Avatar
Default Re: (zex_cool)
ive seen a lot of people with NGK gauges lately. I had a PLX but it got stolen before i could install it. Might get an NGK.
Old Mar 25, 2008 | 01:49 AM
RedR's Avatar
Default Re: (SPOOLINmatt)
been using my plx for over 2 years, never had an issue
Old Mar 25, 2008 | 05:31 AM
morgan@synapse motorsport's Avatar
Default Re: Calling All users of NGK wide band OR PLX-M300 Click here (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">before i "borrowed" my PLX to my buddy i had it snug behind my steering wheel on my 99si, dont have any pictures but i am sure that you get the idea.
Personally i thought and my buddy that still has it is that the PLX unit is a little cheap looking and feeling. I would look more into the gauge type WB02's like the AEM or even the FAST unit. JMO</TD></TR></TABLE>
plx makes gauges too, this gauge and the wideband controller is actually cheaper than the m-300 too:
http://www.plxdevices.com/products/dm5/afr/
or even their customizable organic display:
http://www.plxdevices.com/products/dm200/
ive used my m-300 for over a year now with excellent success. easy to read day or night, responds quick, not to expensive, sensors last a while. all round good for not a bad price. Innovatives are good too.
Old Mar 25, 2008 | 07:07 AM
im thinking of getting the plx.m300 and installing it under my cd player it that lil slot in my integra nice clean install and take 12V from the ncig lighter since i dont smoke
Old Mar 25, 2008 | 07:30 AM
AWDstylez's Avatar
My NGK AFX works flawlessly and the display is large and bright so it's easy to read while driving. The only problem is the lack of datalogging ability. I have mine mounted on the steering column just like you wanted. I'll post pictures when I get home if I can remember.
Old Mar 25, 2008 | 08:50 AM
SovXietday's Avatar
Default Re: (AWDstylez)
I have my M300 sitting right under the the speedometer, easy to see and easy to read.
Old Mar 25, 2008 | 11:17 AM
i really want t seee some pics please ion really all about clean installs and hwo hard are they to install i have the bung weld in all ready and were did you guy take the 12v from thanks
2001B18C1GS-R
Mar 25, 2008 02:08 PM
AllMotorDan
Jan 6, 2005 04:35 AM
JDM_ITR
May 8, 2003 07:18 AM
GOKOOL Mike
14
Mar 23, 2002 01:06 PM
