Compression Tested the R today & the results were ....
Old Mar 24, 2008 | 03:52 PM
99SlammedCivic's Avatar
Snipper Snapper
Default Compression Tested the R today & the results were ....
2000 ITR w/ 150k on the clock.
It smokes under hard acceleration/vtec crossover .
We seafoamed it about 3 weeks ago and it felt a little bit better overall.
I just compression tested it thinking cyl 3 would be bad but we got 230 in every cylinder.
It threw code 45 ( running too rich / running too lean ) about a week ago and then it turned off randomly. It was off for about 3 days and now it turned back on.
Does this mean that it is for sure my valve seals?
Thanks guys & sorry for the newbie question !
Old Mar 24, 2008 | 04:03 PM
Comp97GSR's Avatar
Default Re: Compression Tested the R today & the results were .... (99SlammedCivic)
It is hard to say. Just because you have great compression across the board doesn't mean the oil control rings are still good.
Try a leak down test also. Typically, valve seals will cause oil burn off when a vehicle is first started... HOWEVER, I know of 1 case where valves seals caused excessive oil burning at high revs on the track.
Old Mar 24, 2008 | 04:23 PM
TODAwhore's Avatar
Default Re: Compression Tested the R today & the results were .... (Comp97GSR)
Also check the valve guides..with that many miles i bet the exhaust side are worn.
Old Mar 24, 2008 | 04:41 PM
ITR.#1446's Avatar
Default Re: Compression Tested the R today & the results were .... (TODAwhore)
def need a leakdown done to further diagnose the problem, how much oil do you burn or how often do you have to add oil?
Old Mar 24, 2008 | 04:47 PM
Snipper Snapper
Default Re: Compression Tested the R today & the results were .... (ITR.#1446)
I have only had the car for about 2 months now. I did an oil change about a month ago and it still looks great.
Then again , I dont drive it very often and I dont drive it hard.
Old Mar 29, 2008 | 12:21 PM
2006whitesti's Avatar
Hey I am very interested in the seats you are selling, but I can not post in the FS forums. Please give me a call 865 679 5543
Thanks,
Dustin
alchemyst6
18
Jul 21, 2011 10:08 AM
climb_on
Aug 4, 2007 07:14 PM
iBrandon
Jul 31, 2006 08:03 AM
blackeg
Mar 28, 2005 06:10 AM
gsr stuie
Apr 23, 2002 08:03 PM
