95 Civic No Start... Fuel Pump?
its a 95 civic ls 5 speed. car wont start and has no check engine light. previously it ran shitty(no power, fumbling idle, bucking, hesitation) and does not throw a light. im thinkin the fuel pump is weak. i checked the reisistance of the pump and its 1 ohm. is that normal? also the amperage of it priming and engine cranking is like 4 amps. shouldnt it be more than that? any help is appreciated
Modified by Ehop at 5:42 PM 3/24/2008
You should also check whether you have spark at each of the plugs. This is done by pulling one of the plug wires, putting a good spark plug in the end of it, grounding the plug threads against a convenient metallic part of the engine, and having a buddy crank the engine. You should see a bright spark at the end of the plug. Repeat for the remaining three plug wires. If you lack spark at all the plugs, then you might have a bad coil or igniter unit. Another possibility is that your timing belt snapped.
the gauge i have is a vacuum/fuel pressure gauge and it only reads to 10 psi. it does make pressure but i noticed it didnt instantly rise, it bumped to like 4 then to the full 10 and since the gauge wont read higher so im not sure if its where it needs to be. i went to sears to buy a gauge that reads higher but they only kind they had were the quick connect kind for like fords n other domestics.
Maybe AutoZone or other parts stores will lend you a proper fuel pressure gauge. At AutoZone, you rent a tool by leaving a deposit, which is returned when you bring it back. In essence, the rental is free. It's worth looking into.
Modified by RonJ@HT at 8:00 PM 3/24/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colby71 »</TD></TR><TR><TD CLASS="quote">Having some pressure is no help you need enough for the fuel to atomize coming out of injectors. if you have to low of a presure it will come out in a streem like ****.</TD></TR></TABLE>
i know that, as you can see in my earlier post i tried to get a gauge that read higher but they didnt have it. my point was that it makes 'some' pressure so its not dead, im just thinkin its weak n i wanna be sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ehop »</TD></TR><TR><TD CLASS="quote">
...point was that it makes 'some' pressure so its not dead, im just thinkin its weak n i wanna be sure.</TD></TR></TABLE>
An appropriate fuel pressure gauge should answer your question.
i know that. but i dont have one which is y i asked about amperage draw, something i can measure. but i havent found my answer so i will have to find a gauge with the right fitting.
97accord_R
Aug 30, 2009 06:51 PM
spanishstud
24
May 1, 2009 03:14 AM
