Radiator Leaked! Any good'n affordable OEM replacements
Old Jul 9, 2002 | 08:54 AM
B18C's Avatar
Default Radiator Leaked! Any good'n affordable OEM replacements
Driving downtown last night and then I see the temperature go past the half and quickly rise to the 3/4 mark when I hit a light.
Pull over and look. Drip drip drip.. Radiator was leaking!! ****.
I don't want to pay Fluidyne (spelling) prices. Want something for around $200 that would improve on the original.
I was so scared.. So frustrated.
Thanx in advance.
Old Jul 9, 2002 | 09:48 AM
bps2799's Avatar
Default Re: Radiator Leaked! Any good'n affordable OEM replacements (B18C)
Buy something all metal, rather than the metal core, plastic tank set-up, as these leak after about 100K miles, from personal experience, when the tabs holding the core and tank together fatigue from vibration/pressure and the radiator leaks at the metal/plastic junction. I got an all-metal one installed (was made in indonesia) around 5 years ago in a G2 'teg for $225 US.
Meanwhile, stops-leak(?) bars-leak(?) or something similar, made of, get this, ground up walnut shells, will keep you going for a week or two with no to minimal leakage. Obviously, this crap has to be flushed before the new radiator goes on.
Old Jul 9, 2002 | 10:03 AM
GSG2's Avatar
Default Re: Radiator Leaked! Any good'n affordable OEM replacements (bps2799)
Buy something all metal, rather than the metal core, plastic tank set-up, as these leak after about 100K miles, .
Old Jul 9, 2002 | 10:20 AM
B18C's Avatar
Default Re: Radiator Leaked! Any good'n affordable OEM replacements (jobau)
Thanx for the suggestions guys,
I'll try to see if I can find something soon, before I messup my engine.
There seems to be enough of a difference between the low and the high-end rads.
Old Jul 9, 2002 | 10:25 AM
JMX's Avatar
JMX
it will end up being around 190 bucks i got mine from the local parts shop
30 min install
Old Jul 9, 2002 | 10:34 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: Radiator Leaked! Any good'n affordable OEM replacements (jmx2323)
i got an oem replacement for $135 with tax (8.25%) with plastic endtanks and metal core. make sure you get new upper and lower radiator hoses if you havent changed them. those should be another $20-$30 from autozone or a shop like that.
Old Jul 9, 2002 | 11:14 AM
B18C's Avatar
Default Re: Radiator Leaked! Any good'n affordable OEM replacements (FuknGSR)
Thanks Guys...
I decided to go with a good quality OEM/no-name Rad.
It will cost me $200!!
Old Jul 9, 2002 | 12:26 PM
stick's Avatar
ITR rad is all metal too.
always use OE hoses tho
HankYee
Aug 14, 2009 12:58 PM
str8JDMteggy
Dec 19, 2006 08:16 AM
charms119
Jun 19, 2005 07:48 PM
TegLover4life
May 11, 2003 07:56 PM
Anthony K
Apr 30, 2002 02:34 AM
