which h series tranny is cable
i got an auto cb3 but i got all da parts off a prelude 2 convert it 2 5sp but point being i see da h22 obd1 tranny is hydrolic so i was wondering wat tranny is da 1 that is cable
Why do you want a cable tranny for a 90-93 Accord? Those are normally setup for hydraulic trannies. I don't know of any H series tranny that uses a cable, rather than hydraulics, to actuate the clutch. And if you got all the other parts from the swap then you should have all hydraulic parts should you not?
Are mistaking the cables for the shifter as the cable for an older style tranny/clutch that uses a cable to actuate the clutch?
