Civic Hatch General knowledge HELP ME!!!
Well lets start out by saying I'm a Nissan Buff. But my friend recently bought an rsx-S and I fell in love with the all mighty VTEC. So I recently decided I want a Honda of my own. I decided on going with the K20 swap into a civic hatch. I want an EG or EK but i was doing research on the different models and got confused. What exacally is the difference between the VX EK EG SI? From what I saw they are All the same car except different engines. Is this true? Is the EG an actual model? I've never seen a civic with the tag EG or EK on it. I've only seen the VX and Si badges on those hatches. Someone please Set me straight!
EG is the abbreviated chassis code generally referring to the 92-95 Civic, while the EK is referring to the 96-00 Civic. Technically, North America never got the EG or EK chassis, because our 92-00 Civics were either EH's, EJ's, or EM's.
Now there are trim models for each generation Civic.
92-95 trims were CX, VX, DX, LX, EX, and Si
96-00 trims were CX, DX, LX, GX, HX, EX, and Si
the 'eg and ek' thing are labels. they're the trim/model located in the vin number, its just easiest. Someone wants to talk bout a 99-00 si they talk bout em1, they wanna talk bout jdm hatch w/b16 and rhd, they call it eg6, eh3 = SI hatch (called eg still, for some reason) and eh2 are the other models, i believe.
the difference between VX CX and SI were not only engines, but CX had no power steering (from what i understand)
Engine trim shouldnt matter if you plan to swap, i say cx or vx all the way, they're lighter.
Good luck with the k20 swap, ill be doin one before too long i hope.
Awsome help Thx Kelb,
Umm one other thing. I also want to go for semi-luxury ie. power windows, power steering, Abs and so forth. Does the VX model come with these or is it only Si? I want the civic hatch with horizontal lights that would be 92-95 correct? Thanks for all your help Guys but keep it comming
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGcelent »</TD></TR><TR><TD CLASS="quote">Awsome help Thx Kelb,
!!</TD></TR></TABLE>
The VX does not come with power anything. No, USDM 'EG' had power windows or power locks. The only trim that got some power was the Si, which got power mirrors and a moonroof.
!!</TD></TR></TABLE>The VX does not come with power anything. No, USDM 'EG' had power windows or power locks. The only trim that got some power was the Si, which got power mirrors and a moonroof.
If your looking for a hatch then the SI will give you the most power options of all the hatch backs. they came with power mirrors, power sun roof, cruise control, power steering, and rear disc brakes. If you are looking for abs it was an option on the 95 and I think the 94 SI (good luck finding one with it)
Modified by instructor74 at 7:45 PM 3/23/2008
You're probably going to want to go with the lightest of the chasis and the most stripped down (CX) if you want to go with a K20. Its just easier to do with less things in the engine bay (ps, cruise, abs, a/c, etc)
You can always add power windows and locks later from an EX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">EG is the abbreviated chassis code generally referring to the 92-95 Civic, while the EK is referring to the 96-00 Civic. Technically, North America never got the EG or EK chassis, because our 92-00 Civics were either EH's, EJ's, or EM's.
96-00 trims were CX, DX, LX, GX, HX, EX, and Si</TD></TR></TABLE>
This isn't totally correct. We did get EG chassis here in the US as a few del Sol models and '92-'95 Civic sedan models.
The '98-'00 Civic GX sedan is an EN1.
You'll probably see people say that EKs are all right hand drive (RHD) and from Japan. This isn't true either.
Here is a chart containing as many chassis codes (such as EF, EG, EK, etc.) as I could gather information on.
https://honda-tech.com/zerothread?id=1928390
OP, I hope this helps you out. These are the chassis codes (and engine codes and types) for US '92-'00 Civics.
1992-1995 Civic ("EG") coupe, hatch and sedan
EG8 - D15B7 (1.5L SOHC non-VTEC)
1992-1995 Civic DX sedan
1992-1995 Civic LX sedan
EH2 (1.5L SOHC)
1992-1995 Civic CX hatch (D15B8 - non-VTEC)
1992-1995 Civic DX hatch (D15B7 - non-VTEC)
1992-1995 Civic VX hatch (D15Z1 - VTEC-E)
EH3 - D16Z6 (1.6L SOHC VTEC)
1993-1995 Civic Si hatch
EH9 - D16Z6 (1.6L SOHC VTEC)
1992-1995 Civic EX sedan
EJ1 - D16Z6 (1.6L SOHC VTEC)
1993-1995 Civic EX coupe
EJ2 - D15B7 (1.5L SOHC non-VTEC)
1993-1995 Civic DX coupe
1993-1997 Civic del Sol
EG1 - D15B7 (1.5L SOHC non-VTEC)
1993-1995 del Sol S
EG2 (1.6L DOHC VTEC)
1994-1995 del Sol VTEC (B16A3)
1996-1997 del Sol VTEC (B16A2)
EH6 (1.6L SOHC)
1996-1997 del Sol Si (D16Y8 - VTEC)
1996-1997 del Sol S (D16Y7 - non-VTEC)
1993-1995 del Sol Si (D16Z6 - VTEC)
1996-2000 Civic ("EK") coupe, hatch and sedan
EJ6 - D16Y7 (1.6L SOHC non-VTEC)
1996-2000 Civic DX coupe
1996-2000 Civic CX hatch
1996-2000 Civic DX hatch
1996-2000 Civic DX sedan
1999-2000 Civic DX-V (aka Se aka VP)
1996-2000 Civic LX
EJ7 - D16Y5 (1.6L SOHC VTEC-E)
1996-2000 Civic HX coupe
EJ8 - D16Y8 (1.6L SOHC VTEC)
1996-2000 Civic EX coupe
1996-2000 Civic EX sedan
EM1 - B16A2 (1.6L DOHC VTEC)
1999-2000 Civic Si coupe
EN1 - D16B5 (1.6L SOHC VTEC CNG (Compressed Natural Gas))
1998-2000 Civic GX sedan
I haven't yet finished the 5th ('92-'95)generation chart, but here's a 6th ('96-'00) generation chart for all the factory and optional accessories.
https://honda-tech.com/zerothread?id=2055230
Modified by NOFX at 8:10 AM 5/3/2008
EH2 (1.5L SOHC)
1993-1995 del Sol S
EH6 (1.6L SOHC)
1996-2000 Civic LX
!!</TD></TR></TABLE>I haven't yet finished the 5th ('92-'95)generation chart, but here's a 6th ('96-'00) generation chart for all the factory and optional accessories.
sweet guys thx a lot for your help and suggestions!!!
pennies_hatchie suggested that I get a CX because I'm planning on doing the K20 swap. Would it infact be easier to do the K20 wiring with this chasis seeing how theres no ps,pw, pl? and can I get PS from a different model after the swap is completed? I also heard somewhere that it is harder to wire up the K20 with the nonVTEC wiring harness compared to the VTEC wiring harness. is this true? and Is the CX in fact the lightest? I heard somewhere that the VX is the lightest of models.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">^^^ Show-off. Yes, I forgot about the EG1, EG2, and EG8.</TD></TR></TABLE>
Not showing off. Just posting info. I'm not entirely sure how sarcastic your response might have been.
I've always heard the 6th gen CX is the lightest US 6th gen, I'm not 100% on the 5th gen though... I thought it was the VX, but I could be wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
I've always heard the 6th gen CX is the lightest US 6th gen, I'm not 100% on the 5th gen though... I thought it was the VX, but I could be wrong.</TD></TR></TABLE>
I was being very sarcastic. Your knowledge of the 6th gen is amazing A. I was waiting for you to chime in actually.
The CX and VX models are the lightest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGcelent »</TD></TR><TR><TD CLASS="quote">sweet guys thx a lot for your help and suggestions!!!
You should be okay with the CX as far as powersteering goes as it has a manual steering rack. Its almost as good as ps but without all the hoses and junk that goes along with it. I have a K20 in my DC2 and it cost me a lil bit more to get the powersteering to work. So its definately a luxury that you can go without
As far as wiring goes, its the same for all chasis. You dont even use the stock harness (depending on which aftermarket harness you go with) but I went with hybridracing and it just bypasses all the stock stuff. Its plug and play as long as you have the harness from the K20 and the aftermarket one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">I was being very sarcastic. Your knowledge of the 6th gen is amazing A. I was waiting for you to chime in actually.
The CX and VX models are the lightest.</TD></TR></TABLE>
Oh, okay. I'm just used to some people taking my posts the wrong way (as per my warning in my sig).
I post matter of fact because a lot of what I post is a matter of a fact.
As per what Honda says at least. I figure they have decent knowledge of their cars at least.
mahler29
17
Aug 2, 2007 04:28 PM
d16y8EL
Oct 29, 2003 08:59 PM
rkcivicrcr
12
May 10, 2002 12:30 PM
