b16 stroker
i have a sleeved b16 block and im thinkin of do a built stroker with it. i know it will make real good hp but what will its reliability be. i will be drivin the car pretty often. the build will consist of. and it will be boosted
Godzilla sleeved 85mm b16 block
balanced and blueprinted ls crank
eagle ls rods
forged 9:5 arias, cp's ect not sure yet
itr oil pump
with a b16 or gsr head
skunk 2 valves, springs, retainers
blox mani
65mm tb
eagle ls rods
itr oil pump
blox mani
65mm tb
why didnt you just start with an LS or GSR block? i say keep it the way it is, 85mm gives you a ~1.8 whats your power goal? you can make a lot of power with your setup, i dont see the need for more stroke.
There will be fitment issues with the LS crank in the B16A, as in the pistons will "poke" through the block. That is the only block, where certain hard parts from the B-series will have fitment issues.
You got the torqueless wonder. Change blocks, or simply deal with it. Turbos help with that, but a turbo can only do so much.
well the block i have is already 85mm thats the reason for the bore and as far as pistons go arias can make me a custom set so i will not have any oil issues
