How to?
Old Mar 23, 2008 | 11:59 AM
Cln94EG1's Avatar
Default How to?
I have a AutoMeter Pro Lite Shift Light and I've looked around and can't find out what to hook it too does anyone know or can show me a link or anything pls and thanks
Old Mar 23, 2008 | 12:15 PM
BlueIntegraBoy's Avatar
Default Re: How to? (Cln94EG1)
You can hook up everything to your cluster wires.
Shift light wire ---> Cluster harness wire
1. Green wire ---> Blue wire (tachometer signal)
2. Red wire ---> Black/Yellow wire (12v)
3. Black wire ---> Ground to dash bolt
Old Mar 23, 2008 | 12:19 PM
Luserkid's Avatar
Default Re: How to? (BlueIntegraBoy)
The Pro Lite Shift light is i believe the one with the pills. So the 1, 2, 3 that Blue said is correct. Then you just need whatever pills you would like to use.
Also make sure its set to 4 cylinder
Old Mar 23, 2008 | 12:32 PM
Cln94EG1's Avatar
Default Re: How to? (Luserkid)
No its just the Shift light not the whole Tach heres the picture theres only two wires a White & Black one thats it
Old Mar 23, 2008 | 01:12 PM
afstvx's Avatar
i belive you need a pill box which you hook up to the tack wire then you put the desired rpm pill in then hook th elight to the switch (2 wires one ground and one positive) you cant just hook up the like there has to be an rpm activated switch.
Old Mar 23, 2008 | 01:15 PM
Cln94EG1's Avatar
Default Re: (afstvx)
Thats what I thought but wasn't sure or not
Old Mar 23, 2008 | 01:20 PM
Luserkid's Avatar
Default Re: (Cln94EG1)
Those dont use Pills. These use pills. And thats what i thought you were using.
The ones you have are more of a warning light. We used one for an oil pressure light but was to small and upped it to a bigger one. But you need to run a sender to it. What some people do is (if you have crome/hondata) it has an shift light built in that comes on by the check engine light. You could tap your white wire to the CEL and the black to the ground. Then you change your shift light inside crome. You bought the wrong type of thing if you wanted to change it on the fly.
Edit: if you really want to still use it then you might want to pick up one of these: http://www.streetperformance.c....html
Old Mar 23, 2008 | 01:23 PM
Cln94EG1's Avatar
Default Re: (Luserkid)
Well it was given to me so but ya I just found out that it is a Warning light lol so whats something good to hook it too?
Old Mar 23, 2008 | 01:26 PM
Luserkid's Avatar
Hook it to your CEL, whenever that comes on youll know. Or the seatbelt light to annoy you until you put it on. Ebrake, etc. If you have a D series VTEC engine then hook it up to your VTEC wire, the light will come on everytime you hit VTEC
Old Mar 23, 2008 | 01:28 PM
Cln94EG1's Avatar
Ya thats true lol damn the seat belt light hahaha well thanks for giving me some Ideas now just gotta add some wire and install it
civic-one
Mar 11, 2013 04:28 PM
keith1054
Feb 21, 2009 11:23 AM
ExplicitSpeed360
Dec 8, 2005 08:15 AM
crx_ef8
Mar 10, 2003 10:47 PM
crashtest Sonny
Jun 23, 2002 11:22 PM
