Speedo off by 15 MPH
Where would I start?? When my speed o says I am doing 90MPG...my GPS says I am doing 65MPH...it is very linear...meaning at when it say 45MPH it I am doing 30MPH....always 15MPH high???? Is this something to do with the cluster, or something possibly to do with the gear where the cable goes into the tranny???
I am having issues with the temp gauge for the cluster...I suspect it is a bad ground... but just have not had time to pull it apart... Thx
Oh..it is a '88 civic 1.5L LX model
a) 90 mpg and 65 mph are two different things
b) if you meant 90 mph then that's a 25 mph difference
c) do you have huge riced out wheels that are larger than stock?
assuming you dont have 20 inch wheels on the car, it sounds like you have a poor cluster ground, or a defective cluster.
also inspect the VSS cable for damage.
No I have the stock 13" wheels...I didn't think a bad ground would affect the speedo being it was a mechinal cable....I also have the problem with the temp gauge which I am pretty sure is a ground so that would make sense that I have 2 problems both related to a ground issue....
Sorry, yes I ment 90MPH....not MPG
If your speedo reads higher than your moving, you wheel diameter would be "smaller" not "larger" than stock. Big ricer wheels would make it read slower.
I was told that 13" rims were what stock is??? Was I told wrong??
either way, is there any way of changing something to will get me back to normal? I was thinking the gear in the tranny???
lopezchris21
Sep 18, 2008 11:40 AM
13, 15, 15mph, 20, 2003, 25, accord, civic, crx, honda, mph, spedometer, speedometer, speedomiter, wheels
