Electronic timing controller.....suggest a good one
Old Jul 9, 2002 | 05:12 AM
Stew Pidasso's Avatar
Default Electronic timing controller.....suggest a good one
I'm looking for something that I can adjust my timing electronically.What would you recommend or have heard is good? What kind of pricing am I looking at?
I need to retard my timing to do a higher nitrous shot but I don't want to drive around retarded all of the time. (no pun intended)
Old Jul 9, 2002 | 10:11 AM
badazzaccrd's Avatar
Default Re: Electronic timing controller.....suggest a good one (Nitz5785)
MSD has several you can look into. I have the Start/Retard and it cost me around $120.00. When the Start/Retard is hooked up to the nitrous solenoid, it will automatically retard your ignition, however many degrees depending on what pill you use, when your nitrous solenoid is activated. I'm using a 2 degree pill on a 55 shot.
Old Jul 9, 2002 | 10:16 AM
Brandon's Avatar
Life is Suffering
The Apexi ITC has had a lot of success in my friend's cars. My $.02.
Old Jul 10, 2002 | 04:47 AM
Default Re: Electronic timing controller.....suggest a good one (accordvtec)
I've searched around and I can't find any info on it or who even sells it.Anyone know anything about this?
That MSD Start/Retard sounds like just what I need but must be used with an MSD electronic ignition, correct?
[Modified by Nitz5785, 8:48 AM 7/10/2002]
Old Jul 10, 2002 | 07:16 AM
Brandon's Avatar
Life is Suffering
http://www.nopionline.com
boosted k20
Apr 5, 2005 07:04 AM
baphomet
Oct 14, 2003 06:58 AM
p1ccoloz
Mar 9, 2003 04:18 PM
DaNish
Mar 8, 2002 03:04 PM
