WHAT INT. SHAFT DO I HAVE
You suck relentlessly! Did you do any research at all before you started this god damned project? The search button on the top right of the page has been highlighted in red for a VERY good reason!
I would understand if this was the mid 90's and this info was hard to find, but...this kind of stuff is as basic as an oil change.
If you want to use 90-91 axles, get a 90-91 int shaft.
You probably have a Y1 int shaft and if you want to keep that, you have to get a custom driver's side axle.
Search next time and keep the BS threads out of here. Oh and...TURN OFF THE CAPS!
hatchii
Sep 29, 2003 05:28 AM
biassj
May 16, 2003 03:57 AM
