2002 Tl how do i run wires throught the firewall????
Old Mar 22, 2008 | 09:02 AM
mikess06's Avatar
Default 2002 Tl how do i run wires throught the firewall????
hey guys i cant figure out how to run the wires throught from the engine bay to the trunk, any info would be great thanks..
Old Mar 22, 2008 | 11:42 AM
02 accord's Avatar
Default Re: 2002 Tl how do i run wires throught the firewall???? (mikess06)
Find hole + run wire.
or
Drill hole + run wire.
Old Mar 22, 2008 | 12:48 PM
fcm's Avatar
fcm
Old Fart
Most Honda/Acura, [most cars] will have unused holes in the firewall plugged with rubber or plastic dummy plugs, find a convenient one and use it.
If there are no unused holes or no convenient one, drill your own and install a grommet.
Amp power leads should be kept as short as possible, should be run down the batt, side of the car, should go through the firewall as close to the batt. as practical, should be run in a manner that prevents pinching, chafing and movement.
Remove the back seat of the car and the front seat on batt. side of car, [normally pass. side] remove kick panel trim and sill trim, lift carpet out of the way, wire route should be obvious.
At this point running the RCA leads down the center of the car is easy. 94
RemoveGiantWingOnYourCar
May 10, 2007 04:00 PM
noob with an RS
Audio / Security / Video
Dec 30, 2004 05:13 AM
b16egsi
Oct 26, 2003 08:50 AM
schwinn
Jun 11, 2002 06:05 PM
Volcom
Dec 30, 2001 11:49 AM
