Installing a system
Installing a system
Does anyone have a diagram on how to install a system with the best way to hide the wires. Again I posted in the Audio section but no-one goes there so my questions go unanswered...
Re: Installing a system (bcmatzen)
For the amp's power wire, run it through the grommet behind battery. Run all the wires under the carpet and use zip ties under the dash if needed. It's not very hard. I think Crutchfield actually has How-Tos on all the connections to be made.
http://www.installdr.com, too.
Re: Installing a system (clm)
Depends on where you are going to put the amp. If it's going in the seat, then just pull the panels that cover the door sills on the car. I've heard that running the wires right there can cause "noise" on them, but have installed probally 50 setups, and never had trouble with it. Just run it through that grommet mentioned above and run it along the side of the car (under that panel) all the way up and under the back seat.
mikess06
Audio / Security / Video
03-22-2008 12:48 PM
Volcom
12-30-2001 11:49 AM
