Coil Bind/Bump Stop
I put some springs on the other day for the first time. Front 1.5" Drop, Rear 1.35" Drop. When I hit small bumps or pot holes if going a little to fast it seems to bottm out in the front. Checked front and the very top part of the coil on the bottom the paint has rubbed off a little and started to rust. I think I set the bumper stop to low. I am going to adjust it up this next weekend and see if it makes a difference. If it does not bottom out any more after I adjust the bumper is the coil still ok? do I need to patch the rusted spot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">if you used lowering springs, it is completly normal for them to coil bind, they are progressive springs, it is how they work</TD></TR></TABLE>
even if it's completely unloaded? what is the reason for them to be there in the first place?
Jonovision
27
Sep 10, 2007 05:42 PM
kent
Jan 6, 2003 10:24 AM
