"how to correct timing for dummies"
Old Mar 22, 2008 | 07:39 AM
95ludeSE_bottle's Avatar
Default "how to correct timing for dummies"
hi to all - i just registered to this site............
car info: 1995 prelude se h23a
mods: intake, header, exhaust, complete ignition system, NOS
heres my deal
my time belt broke about 2 months ago- i choose to to let a local shop fix the problem- when the belt broke it bent 4 valves- the valves were replaced and the gaskets from the head gasket up was replaced- i choose not to goto machine shop with the head because the car never ran hot and its only got 96000 miles on it- the shop manager also used a tool which i forget the name of and he sd it was level- fast forward a week later i get my car back- the head gasket is leaking oil! guess i shouldnt had cut the cost saving corner of going to a machine shop- so the lude goes back for "warranty" work...... they repalce the head gasket with a "better" one and sent the heads to the machine shop- fast forward about 2 weeks later--- finally i get my car back- i was so excited- first of all i notice a whislting sound form the motor- first i thought maybe they added a turbo for no charge due to the aggrevation i have been thru the past month- but i popped the hood no such luck- i was thinking exhaust leak but it sounds like it coming from the crank pulley, the car doesnt seem as peppy- but i'm thinking the temp here has warmed up alot since my baby has been down for 2 months- however when i get it home it doesnt want to idle right at all- even goes dead sometimes(it has never did this) there seems to be a noticable power loss- and my air fuel meter is reading rich while idling- i pulled the plugs(they are black as ****) so i'm assuming running extremely rich- and i'm also assuming due to timing. power loss , black plugs, crappy idle, o and found about 5 drops of oil on my shop floor- this is the first time i have let anyone touch my car other than me and friends-- because i dont know anything about setting the timing- my question is would incorrect timing cause these probs(all except the oil leak and whislting ofcourse)
Old Mar 23, 2008 | 11:12 AM
sup3rd's Avatar
Default Re: "how to correct timing for dummies" (95ludeSE_bottle)
Ahhh. Try correcting the spark timing. Cause when we did it on the mustang in my auto class that thing would idle like **** until we got it just right.
Old Mar 23, 2008 | 11:15 AM
Hawkze_2.3's Avatar
Yes, the first thing I would do is double check your ignition timing and cam timing...if those aren't right the car will never run good.
NeilR7
Mar 22, 2014 09:00 AM
01_civic
Classic Hondas
Sep 15, 2008 07:42 PM
waciii
Sep 7, 2008 09:00 PM
NikeSB
18
Jul 10, 2006 05:27 PM
