OBD2 ITR harness into 92 EG with P28, Do I need to make any wiring changes for the OBD2 distributor?
OBD2 ITR harness into 92 EG with P28, Do I need to make any wiring changes for the OBD2 distributor or is the distributor connector plug and play?
actually I guess its the plug at the shock tower I would possibly need to adjust, not at the distributor. shock tower sub harness is OBD1, engine harness/distributor is OBD2 ITR.
im curious about this too cause i've got an itr swap with the obd2 harness and dropping it into a 92 cx. so i can just plug the obd2 engine harness to the shock tower and keep the obd2 alt and dizzy? and use a chip p28. also do i have to do anything to the obd1 sub harness from the ecu?
Nope. So long as you run the chipped P28.
Neukin
Feb 22, 2003 10:39 AM
Blown90hatcH
Feb 11, 2003 01:26 PM
