where to mount my prox sensor on a newer civic
Old Mar 21, 2008 | 11:46 PM
Xxcivic99xX's Avatar
Default where to mount my prox sensor on a newer civic
ive got the avantguard 5 from clifford on my 07 SI
I had the prox sensor mounted inside the headliner, right above the map light. it did not work well when it was mounted there.....
So i remounted it right inside the center console. not under the console but inside. It works pretty well in there. but is there a better spot i can where i can mount it so it can not been seen?
Thanks
Old Mar 22, 2008 | 07:05 AM
fcm's Avatar
fcm
Old Fart
Default Re: where to mount my prox sensor on a newer civic (Xxcivic99xX)
I have mounded proximity sensors under the headliner many many times with very good results, much more uniform coverage around the car, and coverage below the windows.
What was the problem you had when mounted under the headliner? 94
Old Mar 22, 2008 | 09:46 AM
Default Re: where to mount my prox sensor on a newer civic (fcm)
it was giving off a lot of false triggers.....
and when it was set down, it wasnt picking up anything
Old Mar 22, 2008 | 12:09 PM
fcm's Avatar
fcm
Old Fart
How is it working now?
The Alpine dual stage "radar" sensor I have in my LS is mounted under the console, just behind the shifter and works perfectly when I set my hand brake up out of the way.
I have found with all proximity sensors you get the best results when sensor is mounted 1/8"-1/4" above the cars floor pan, [or under the cars roof] double sided tape and Velcro pads work well, the sensor should be grounded to that metal surface, or as close to it as possible, the metal surface becomes part of the sensors ant., [ground plane].
This can be a bit of a problem with sensors that use the alarms ground out when armed as their ground, [so they are not on when alarm is not armed] easily fixed with a relay.
No metals of any kind should be above the sensor, nothing like a some change or foil gum or cigarette wrapper to screw up the sensor.
Adjustment is critical to proper performance, the "outside" zone, [warn-away trigger mode] should be adjusted to no more then 12" past the ends of the side mirrors, keep in mind the "radar" is "looking" for mass moving towards or away from it, it's speed and the masses proximity to the sensor, the more mass the object has the farther away the sensor can "see" it.
The inside zone, [full alarming trigger mode] should be adjusted to about 6" inside the windows.
The importent thing to remember is not to have the outside and inside zone boundaries too close together. 94
Old Mar 22, 2008 | 12:57 PM
yeh thanks for the info.....
its working really well now....
i just dont like how its visible inside the arm console when i open the box.... but when i removed the console.....there was mental everywhere, and i thought that would give off false triggers. the first sensor i had in the roof...it gave off a lot of false triggers; i think the sensor was bad....but then i got a new one and re-moiunted there(headliner)and it didnt work well at all.
but im tryiny to think of a place to remount it.
Im not sure what kind of prox sensors they are, its from the avantguard5.
I had originally had a local shop install this system, later found out it was a crappy job and had a different guy from the place re-do. since then the brain had to be replaced(my horn was coming on when the alarm triggered), tilt has been faulty, and prox sensor had a prob. so ive still been skeptical about this whole alarm in the car
Old Mar 22, 2008 | 03:52 PM
JSPECSIR's Avatar
is there enought room to mount it inside of your armrest on the console?
Old Mar 22, 2008 | 04:16 PM
fcm's Avatar
fcm
Old Fart
I would put the blame for your problems with that alarm on the installs, I have installed many more then a few of the AvantGuard 5 systems and have found them very dependable, most of the proximity sensors I installed under the headliner are for the AvantGuard 5 systems.
From the install guide...
remote adjustable proximity sensor
The proximity sensor input circuitry has been improved for G5 so the sensor only has power when the alarm is armed. While driving this protects highly sensitive vehicle electronics (i.e. radar detectors) that can be affected by outside interference.
However, this does change the way the sensor is adjusted but will not affect normal operation of the sensor.
locating the proximity sensor
Inside the vehicle's headliner is the optimal mounting location for this sensor and
should always be the first choice. The sensor should face down, centered side to side, with the wire harness exiting toward the front of the vehicle.
I try and install them just in front of the dome light, it has always worked very well. 94
Old Mar 22, 2008 | 08:04 PM
Default Re: where to mount my prox sensor on a newer civic (JSPECSIR)
yeah its mounted inside the arm rest right now. i just dont like how its visible when i open the arm rest. Everything under the console is full of metal.....so i dont want to risk any false triggers...
could there be something wrong with the wiring itself for the prox to be set too sensitive and giving off false triggers under the map light or not work at all?
i might try to reinstall it there again.
Old Mar 23, 2008 | 07:12 AM
fcm's Avatar
fcm
Old Fart
Remember there can be nothing metallic in front of the sensor, [above it when mounted in the console or below it when mounted in the head liner.
What exactly do you mean by " under the map light "? 94
Old Mar 23, 2008 | 04:20 PM
2boysboostin's Avatar
center of the car.
Old Mar 25, 2008 | 05:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Remember there can be nothing metallic in front of the sensor, [above it when mounted in the console or below it when mounted in the head liner.
What exactly do you mean by " under the map light "? 94</TD></TR></TABLE>
sorry i meant above the map light, in the headliner
Old Mar 25, 2008 | 06:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xxcivic99xX &raquo;</TD></TR><TR><TD CLASS="quote">
sorry i meant above the map light, in the headliner</TD></TR></TABLE> Sorry still not clear.
The sensor should be mounted close to the center of the car, just in front of the dome light, and as mentioned with nothing metallic over the "front/face" of the sensor. 94
Old Mar 26, 2008 | 08:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Sorry still not clear.
The sensor should be mounted close to the center of the car, just in front of the dome light, and as mentioned with nothing metallic over the "front/face" of the sensor. 94</TD></TR></TABLE>
I meant, remove the screws that hold in the map light. and place the prox sensor aan inch away from it towards the sunroof(rear of the car),mount on the roof with double sided tape. having the radar field detecting downwards inside the car.
Old Mar 27, 2008 | 05:18 AM
fcm's Avatar
fcm
Old Fart
OIC, that should work, not sure why it does not. 94
w211 ryda
Audio / Security / Video
Feb 16, 2010 08:41 PM
D50boy
Feb 22, 2008 12:46 PM
Understeer
Nov 23, 2002 04:27 PM
cw_civic
18
Nov 18, 2002 01:51 PM
cw_civic
Jul 25, 2002 05:26 PM
