Brake issue, won't let go
So having an issue with the brakes on the car. It seems as you drive the car, and use the brakes, they slowly keep clamping tighter and tighter, so like after the first 2-3 stops the brakes are almost engaged enough to stop the car on their own. When you pull the vacuum line from the booster, they go back to normal, plug it in and drive a couple stops and same deal. I'm guessing a booster or master cylinder, but any other ideas?
Eighty-Nyne
Apr 21, 2009 07:30 AM
kurinto
16
May 4, 2005 03:42 PM
Filliam H. Muffman
14
Aug 2, 2004 06:24 PM
