OEM Type R Clutch
Old Mar 21, 2008 | 10:21 PM
garyc17's Avatar
Default OEM Type R Clutch
Will an OEM DC2 Type R clutch and pressure plate hold 210HP at wheel? This is a NA setup. If not, any recommendations?
Old Mar 21, 2008 | 10:36 PM
b18c5 EG's Avatar
bump...i would like to know the same.....
Old Mar 22, 2008 | 11:06 AM
garyc17's Avatar
I'm sure someone knows this....
Old Mar 22, 2008 | 11:11 AM
aznej2's Avatar
Default Re: (garyc17)
yes it will i made 217 whp wit my type r build with stock clutch
Old Mar 22, 2008 | 11:24 AM
b18c5 EG's Avatar
good im gonna be around 190 hp....i actually have a brand new b16 clutch but it should be the same correct? i thought all bseries were the same
Old Mar 25, 2008 | 04:18 AM
garyc17's Avatar
Any slightest bit of slippage say around 9000rpm?
Old Mar 25, 2008 | 05:39 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (b18c5 EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c5 EG &raquo;</TD></TR><TR><TD CLASS="quote">good im gonna be around 190 hp....i actually have a brand new b16 clutch but it should be the same correct? i thought all bseries were the same</TD></TR></TABLE>
For what it's worth the OE ITR clutch has it's own completely separate part number for the pressure plate or "clutch cover" as they call it sometimes.
The disc is the same as GS-R I believe.
Now when it comes to buying aftermarket clutches all 92-up B series clutches are interchangable. 90/91 had smller mainshaft diameters, thus smaller splined clutch discs.
Old Mar 25, 2008 | 06:28 AM
IIXtremeHansen's Avatar
Default Re: OEM Type R Clutch (garyc17)
Yes OEM Type R is fine. Ill Upgrade if its over 240
Old Mar 25, 2008 | 06:37 AM
aznej2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Any slightest bit of slippage say around 9000rpm?</TD></TR></TABLE> my motor wasnt built for 9000 rpm... and if ur building a motor that is still making power at 9000 y not just get a new clutch ?
Old Mar 25, 2008 | 07:42 AM
2doorcivic's Avatar
good ?
Old Mar 26, 2008 | 11:37 AM
garyc17's Avatar
Default Re: (aznej2)
I'm on an Excedy 3 puck now but I hate the vibration when I ride the clutch at a certain point. And the clutch pedal is way too stiff for city driving especially in a jam. It could be my pressure plate which is due for change, but I just want something with a more OEM feel in the clutch.
Old Mar 26, 2008 | 09:44 PM
aznej2's Avatar
toda disk
Old Mar 26, 2008 | 11:01 PM
bmoua's Avatar
i'm sure the OEM ITR clutch will handle that no prob. now if your planning to go anywhere from 250hp+ i'd def upgrade to a stage 1/2 clutch
Old Mar 27, 2008 | 08:08 AM
garyc17's Avatar
Another problem with aftermarket high pressure plates. They kill your clutch master cylinder fast!
kyw3
Jan 4, 2007 12:19 PM
97 Sleeper
Sep 26, 2005 07:34 AM
WTR
Jul 12, 2005 10:35 PM
b16vtecsol
May 13, 2004 06:59 PM
superboy
Aug 23, 2003 03:52 AM
