i need help with trailing arm replacement
Old Mar 21, 2008 | 08:11 PM
E.'s Avatar
E.
Default i need help
how could i take off the parking brake line off the caliper and the trailing arm with out breaking nothing because the parking brake line goes throw a hole on the trailing arm and the only think holding meback is the parking line some one plese help me....................................... i need to replace the trailing arm.
Old Mar 21, 2008 | 08:56 PM
BlueIntegraBoy's Avatar
Default Re: i need help (E.)
That's easy. You can remove the ebrake cable from the ebrake handle or remove it from the caliper.
1. To remove it from the ebrake handle, remove the armrest to access the butt end of the handle. Remove it is self-explanatory. Then remove the #13 bolts to unbolt it from the chassis.
2. Remove the cotter pin (#20) connecting the cable to the caliper. Then remove #19 to unhook the cable to the mounting bracket. Remove the #14 bolt to unbolt it from the trailing arm.
Old Mar 27, 2008 | 08:20 PM
E.'s Avatar
E.
thanks dude u are a hero
ArinX
Suspension & Brakes
105
Jul 17, 2011 09:04 AM
imadigitalgod
Sep 2, 2010 10:08 AM
jjlaho
Suspension & Brakes
Jun 8, 2010 05:56 AM
bsivoljr
Dec 21, 2009 11:20 PM
Thrillhouse
20
Oct 25, 2005 09:26 PM
