SOHC Timing Advace.
Old Jul 8, 2002 | 11:47 PM
Turbo Powa's Avatar
Default SOHC Timing Advace.
Does anyone know how much timing advace I can do on a SOHC D16Y7 to get some extra boost? I need all information as possible. If you have already done it to your car please leave detailed instructions. Thanks!!
Old Jul 9, 2002 | 03:18 AM
gavhowe's Avatar
Default Re: SOHC Timing Advace. (Civic LX 29)
I am currently trying to find that out too my engines a D16Z6. someone must have experience.
Old Jul 9, 2002 | 09:43 AM
Turbo Powa's Avatar
Default Re: SOHC Timing Advace. (gavhowe)
Anybody else?
Old Jul 9, 2002 | 09:56 AM
RStoR's Avatar
Look under your hood! Sticker will tell you OE setting and +/- figure. A bump within spec. usually helps.
Old Jul 9, 2002 | 11:03 AM
DOHC-DX's Avatar
Default Re: SOHC Timing Advace. (RStoR)
yes, do not go beyond spec. for almost all honda engines, timing should be 16deg BTDC (-/+ 2deg)
Old Jul 9, 2002 | 11:10 AM
builthatch's Avatar
MiG-21 superfan
stock for the y7 is 12 btdc +/- 2....i would try 16/18/20 degrees, run premium gas, read the plugs for lil metal spex/pepper and listen for pinging...i doubt youll audibly ping even @ 20++ btdc
[Modified by builthatch, 3:11 PM 7/9/2002]
Old Jul 9, 2002 | 11:11 AM
poison's Avatar
advancing your timing won't do much you just might get 1 hp difference at top end.
you will need to run higher octane gas.
all you do is disconnect your negative terminal on your battery, loosen up the bolts on the distributor, and turn it towards the firewall.
u don't want to advance it too much.
my advise is just to leave it stock timing. that's the best.
Old Jul 9, 2002 | 01:31 PM
Turbo Powa's Avatar
Default Re: SOHC Timing Advace. (poison)
so how would I be able to get better throttle response and mid or top end power without having to spend alot of money?
Old Jul 9, 2002 | 02:09 PM
poison's Avatar
yes very little, if you advance it like 2 degrees. get a timing light and use the timing light. you don't want to advance it too much
know what you are doing & what it does before you touch anything in the engine bay. otherwise it's best left alone.
Old Jul 9, 2002 | 04:52 PM
Turbo Powa's Avatar
Thanks.... I think i'll probably back off cuz I sure as hell do not know what I am doing. Thanks for your great posts poison.
661rex89si
Jun 15, 2006 12:29 AM
Dr. D-Series
Apr 23, 2005 05:24 AM
civickid77
Sep 26, 2002 10:05 AM
Turbo Powa
Jul 9, 2002 10:34 PM
