capability of greddy 18g (max power and on what size injectors)?
Old Mar 21, 2008 | 11:40 AM
touandcim's Avatar
Default capability of greddy 18g (max power and on what size injectors)?
hey everyone. i have an greddy 18g kit bolted on my si. i know it definitely isn't the best kit out there, but it is very streetable. My questions are:
1. what is the max whp that the kit is capable of?
2. i have an extra set of saturated 750cc's, these should provide sufficient enough fuel for this kit maxed out, right?
3. are there any prefabricated bolt-on mini-rams and downpipes available for this kit?
4. also, how much flow does the stock fuel pump provide? will i need to upgrade to something with more flow and if, walbro 195 or 255?
thanks in advance!
Old Mar 21, 2008 | 12:59 PM
touandcim's Avatar
Default Re: capability of greddy 18g (max power and on what size injectors)? (touandcim)
ne1? ttt for answers!
Old Mar 21, 2008 | 01:14 PM
nfn15037's Avatar
Default Re: capability of greddy 18g (touandcim)
4 threads below yours is a 9 page thread on this very topic.
https://honda-tech.com/zerothread/1836946
Old Mar 21, 2008 | 04:40 PM
touandcim's Avatar
Default Re: capability of greddy 18g (nfn15037)
thanks man. usually i look or search but i never have much faith in it.
Old Mar 21, 2008 | 06:54 PM
Liquidgsr's Avatar
I made 300whp at 15psi with 440cc injectors. Im sure you make 400-450whp out of it with a upgraded manifold, external wastegate, and 3" downpipe with will not let you keep AC.
Old Mar 21, 2008 | 08:29 PM
quicksilver1689's Avatar
i ♥ snails
450whp from an 18g?
Old Mar 21, 2008 | 08:41 PM
Liquidgsr's Avatar
Default Re: (quicksilver1689)
im only guessing......there people on here that have different style manifolds....
Old Mar 22, 2008 | 11:40 AM
TheShodan's Avatar
Moderator
Default Re: (Liquidgsr)
450whp on an 18G is stretching it at the least. That's at over 25-30psi thrown at it, and is not recommended by any means. The turbo is good to about 350whp realistically, and works well with Honda motors for a nice street push. The only limiting factors are the internal wastegate flapper door, which causes some problems, simply because of its small diameter (about 32mm)
Old Mar 22, 2008 | 12:10 PM
touandcim's Avatar
thanks. but methinks i got a bigger problem now than just worrying about turbo specs. i'm pretty sure my head gasket's blown. **** on me, since i'm an amateur mechanic at best. i'm gonna try to do it myself-and learn since i figure i'm probably going to be dickin around with honda inline fours for a long time coming. thanks guys.
Old Apr 3, 2008 | 11:03 AM
2s1owsi's Avatar
on my 00 civic si with greddy 18g, i made 256 @13psi. My comptech exhaust (2.25in) rob hp, i have now switched to 3in exhaust.
Oleg
Jul 17, 2006 05:50 AM
kcjohnnyboy
Dec 30, 2005 10:51 PM
VTECisSeXY
May 4, 2004 06:13 PM
Chillinit
Nov 16, 2003 09:14 PM
HiGhCaM
Nov 24, 2001 08:23 AM
