b16 leaking cam seal
I thought it was the vtec solenoid leaking, but after i got it off, i realized the oil was coming from the bottom of that black cap at the end of the cam. so I need to replace that, anyone know how hard it is? doesn't look too bad, just wondering. also, i would like everyone's opinion on what could happen running with that leak. i probably won't be able to get in there for a couple weeks to get it fixed, and I wonder if I should really baby the car for a while or if i can drive normally. just wondering if that leak will affect oil pressure enough to cause a problem. it is just a small leak, not spraying or anything. thanks.
oh damn, the whole cam has to come out? i can't just pull out the old seal and put in a new one? shoot, maybe new cams then while i'm doing that, hehe. damn, that means timing, again. done it so many times recently i can do it in 2.5 hours now.
If the oil leak is from the cam cap, then NO the cam does NOT have to come out. I don't think theres ANY type of oil leak that has removing a cam involved in any part of fixing it. Anyways, theres a FAQ around here somewhere, I did it myself in a few minutes. Its a very typical b series symptom. The biggest thing you need to keep in mind, is torquing everything to SPEC.
https://honda-tech.com/zerothread?id=953151
torque specs FAQ
Try searching for a cam cap DIY. Good luck!
torque specs FAQ
cool thanks. i've got the manual, just haven't looked at it yet. it's just a little leak, looks to be coming from the very bottom of that black cap. hopefully it's a simple fix. torque specs are good, thanks.
hondatuner20
13
Mar 4, 2006 06:38 PM
Austin
Jul 26, 2005 08:14 PM
