b16 problem at high rpm
ok just setup is b16a2 on 6 psi
i just got the swap finished into my new shell and now it seems if i go anywhere over 6k rpm, as soon as i put the car in neutral the car idles like its about to shut off, maybe less then 500 rpm and if i try to drive it will sputter and drive like ****... Now if i go past 6k and the problem starts, as soon as i turn the car off and on it runs normal
and the biggest thing that has me stumped is that theres no cel's at any point
i hope someone has had this problem and can help
a tech at my work said that it could be a problem that vtec is causing, he is suggewsting that since this only happens after 5500 rpm (vtec's engage point) that the vtec lobe on the cam gets stuck and isnt releasing... does that sound right at all?
No, that doesnt sound right. If it was stuck open, there would be a cel. Have you tried inspecting the simple things first? Such as spark plugs, plug gap, ignition timing?
Modified by yoffer at 8:57 AM 3/21/2008
i havent yet only because if there was a problem with any of those then it would be a consistent problem not just when i go deep into the rpm range :/
yes its tuned on crome pro, timing belt wate rpump and tens is getting done as we speak... my cousin suggested ECU but i dont understand why that would be the problem there was no problem with it in my 93 dx, and now its in a 95 cx...( also anyone know why my damn cruise control light is on...?)
Ok. A faulty ECU would probably be shown as a Solid CEL with no codes, and very likely limp mode, which you're obviously not in. But maybe its a wrong ECU? I've read here about weird issues with non vtec ECU's used on VTEC engines and so on. Anyways, I know nothing about ECU's lol, but open her up and check her out inside. ( Shot in the dark here) GOod luck! And let us know what happens after doing timing belt!
few questions i have... is this a stock b16? have you removed and replaced any parts? what ecu are u using and have you checked to make sure all your vaccum lines are hooked up correctly?
this is a stock b16, only have a blox intake mani, replace the clutch kit and flywheel, p28 chipped and tuned on crome pro, only diff vaccum line i hooke up that wasnt connected in my dx was a line that went to the evap cannister and thats the only line that goes to it, thats connected
i had a similar problem like this after i changed my manifold and tb... it was due to not tightning the bolts enough and the gasket wasnt sealing... some food for thought. since ur not throwing any cel's i doubt it has anything to do with the ecu... it is probably sumting mechanical. have u tried listening for a leak yet?
ok so... new timing belt water pump, and tens... new cap rotor and plugs, double checked all wiring and still no CEL for this problem.... i give up, is there any differences that could casue this with the different chassis?
Could be the crank/cam sensor gone bad or lots of noise in the circuit. Unless you have an oscilloscope, the easiest way to check it is to swap it out or change the dizzy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 »</TD></TR><TR><TD CLASS="quote">and now its in a 95 cx?</TD></TR></TABLE>
Last I heard, those cars only had 70 hp, so if you're using that fuel pump, your starving the engine out for fuel, especially with a turbo.
yea i still have the stock pump in, i guess im gonna throw the integra pump i have in for now untill i can get to the store and get a civic pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 »</TD></TR><TR><TD CLASS="quote">yea i still have the stock pump in, i guess im gonna throw the integra pump i have in for now untill i can get to the store and get a civic pump
No, no. Aftermarket high flow. Walbro or the like. You have forced induction. I dont care for stock pumps and FI, even if the kit says you won't need one.
</TD></TR></TABLE>No, no. Aftermarket high flow. Walbro or the like. You have forced induction. I dont care for stock pumps and FI, even if the kit says you won't need one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">Good luck!
. </TD></TR></TABLE>ty sir,
to you for hopefully fixin my problem
