wierd clutch problem with 97 SH
Old Mar 20, 2008 | 09:24 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default wierd clutch problem with 97 SH
ok my bros SH is doin something i never seen
it turns on fine, i push in the clutch and turn the key and crank it then let go of the clutch
then when you have it in neutral and push the clutch in it boggs the motor down and shuts it off
so has anyone ever had this problem?
Old Mar 20, 2008 | 09:27 PM
JasonST's Avatar
Default Re: wierd clutch problem with 97 SH (raylude)
So ur saying that when u push the clutch in the car dies? Hmm that's kinda odd, only thing I can think of is maybe ur thrust bearings are going out, causing the crank to move just a tad too far so the crank position sensor can't read and then turns the car off. Does the car start fine with the clutch pushed all the way to the floor?
khronicboy420
Nov 25, 2013 05:41 AM
vinceg143
Aug 20, 2008 03:24 PM
Sinner
Mar 24, 2004 04:50 PM
igyloo
Jun 29, 2003 06:07 PM
