A Few Quick Questions
Tearing down my HMotors pallet and I just wanted to ask a few questions...
First thing I did was take off the valve cover just to take a look around, didn't do a thorough inspection yet but I assume the color looks good right?
Next I saw this setup and noticed that one my H23 the FPR is directly connected to the intake manifold. Is this piece going to be needed as I assume my H23 harness does not have a plug for it.
And one last question, I was just curious as to if my automatic shifter assembly will have the three rubber cushions that are missing from this plate? I haven't had a chance to take my console apart due to the fact that this is my DD.
To awnser your First and Second question here are the awnser
Question 1= Yes, seemingly looks okay
Question 2= Thats the JDM Solenoid of some kind. In USDM they keep those on the fire wall. You wont need that. Just plug your FPR into the Vaccum port on the front of the Plennum. Shouldnt be more than 4 inches away from the FPR
Modified by Acidcrakker at 11:55 PM 3/20/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">
Question 2= Thats the JDM map sensor. In USDM they keep those on the fire wall. You wont need that. Just plug your FPR into the Vaccum port on the front of the Plennum. Shouldnt be more than 4 inches away from the FPR</TD></TR></TABLE>
that is NOT the map sensor.
Well I did search the valve and I knew what it was, more or less I was just seeing if anyone has come up with a reason to keep it yet. Would be nice if someone could modify it to work as an adjustable FPR.
The only problem I had with the engine was that the bracket that valve is mounted to was broken and one of the tabs on the shifter boot was missing. Hmotors was even kind enough to unbolt the TPS and tuck it under the manifold to make sure it wasn't broken.
Sorry to pull this one from the graveyard but I have an update and a few questions.
I tried ordering the rubber shifter plate bushings from a local dealer but the metal collar was on backorder. I figured I'd try my luck with Majestic to see if they had any in current stock but still no luck. I am waiting on the rubber pieces of the bushings to get shipped to the local dealer. Not going to do me any good without the collar. So out of the the two options suggested by previous replies what would be the best solution? Would I honestly see any negative effects of bypassing the rubber?
I might just go buy the shorter bolts and four thin plastic/rubber washers just to help it seat and absorb at least a little bit of vibration. Do you remember the size and thread pattern of the bolts? Mine didn't come with any of them.
