Tire Sizing on EG?
I have a 95 eg and was woundering what tire size should fit better on 15x6.5in. rims? 195-50-15 or 205-50-15? i know that turnability my be sacraficed and traction with the 195's but will 205's rub on the fenderwall under heavy turning?
thanx fellaz
thanx fellaz
I've got 205-40-16's on my car. Only rubs a little on the rear if I've got passengers. I'm lowered 2-2.5" with camber correction, so rubbing is virtually never an issue.
Go with the 205s, you won't regret the advantages.
i had 195-55-15s and they would rub on tight turns. when i had to replace them, i went w/205-50-15s and had no problems. i'm only dropped on eibach sportlines too
dAndOg130
Oct 1, 2003 07:04 AM
