95, 96, 97 Honda owners ! FREE SERVICES !
I found this on another board somewhere..maybe some of you dont know about it...
I have a 97 Integra, but this deal applies to other models as well.... Apparently, Honda's on board diag system has a technical problem and they have an agreement with the federal clean air act to hook us up. Here is the deal summary:
1. 50k-75k miles you get a free emissions inspection and any repairs or replacements are done FOR FREE.
2. 75k - 150k miles you get another free emissions inspection, etc. BUT YOU ALSO GET NEW SPARK PLUGS, IGNITION WIRES, DISTRIBUTOR CAP AND ROTER, AND OIL CHANGE FOR FREE !!!!!!
3. Emissions warranty has been extended to 14 years
4. IF YOU HAVE PAID FOR ANY OF THE ABOVE EMMISIONS PARTS/REPAIRS YOU CAN GET REIMBURSED!!!!
Attached is a copy of the letter..... Make your appointments now....
http://www.badongo.com/file/8382208
Modified by njcgsr at 3:16 PM 3/20/2008
I just picked up a used 1997 Integra GSR with 77,777 miles on it.
The previous owner gave me a bunch or receipt/records along with the car and I found a receipt for 75K-150K service done by the Acura dealer. The total cost said $0.00
They replaced the rotor, plugs, oil change etc... Basically they did everything you mentioned for free.
For the longest time I couldn't understand why they did that for free and now I know.
Thanks for the info man.
so i have a 96 integra with 135k miles, however i dont have any old warranty papers or original paperwork or anything because i bought the car from a previous owner (duhh) but not dealership. so would i just call acura and make an appointment? and they would look up my vin or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_Du_Ma_Mai »</TD></TR><TR><TD CLASS="quote">so i have a 96 integra with 135k miles, however i dont have any old warranty papers or original paperwork or anything because i bought the car from a previous owner (duhh) but not dealership. so would i just call acura and make an appointment? and they would look up my vin or something?</TD></TR></TABLE>
Ya you just need to give them the vin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Thanks for being helpful, but welcome to 2006.
https://honda-tech.com/zerothread?id=1528650</TD></TR></TABLE>
Well i know it came out in 2006,but i didnt have my car in 2006 so it helped me out.
had this done when i bought my 96 back in '06, [freak]ing awesome, got everything said in the first post, go in there and complain
also, my stock header was cracked, and they replaced it free!
I'm in the process of polishing my stock muffler (only did 60 grit) and I just found that the piping connected to the muffler has a crack around it. Will they replace my exhaust even though ive started to polish it? Someone please chime in, thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urban_LegendGS-R »</TD></TR><TR><TD CLASS="quote">the letter is dated jan 2006... does this matter? so i just print off the letter, and take it to them.. and make an appointment at the same time? im kind of lost if you cannot tell. </TD></TR></TABLE>
No it does not matter. You can print it off or just call the dealership and give them your vin and make an appointment for an emissions control inspection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahhhdam »</TD></TR><TR><TD CLASS="quote">I'm in the process of polishing my stock muffler (only did 60 grit) and I just found that the piping connected to the muffler has a crack around it. Will they replace my exhaust even though ive started to polish it? Someone please chime in, thanks in advance.
They should cover it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu »</TD></TR><TR><TD CLASS="quote">do those services apply to modded cars?
i go to the nearest honda/acura dealership? (only if 1st question applies)
i also bought my car from another owner</TD></TR></TABLE>
Probably not but it wouldnt hurt to call the dealership and ask and you would need to just call and give them your vin and make an appointment.
</TD></TR></TABLE>They should cover it.
Wish I knew about this in '06 when my mileage was still low enough to make the cut-off. Oh well. And I have had to replace all the items mentioned in this thread so far. damn it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20quang »</TD></TR><TR><TD CLASS="quote">will this work on a car with over 200k miles on it</TD></TR></TABLE>
150k is the cutoff.
150k is the cutoff.
ok so im running on an aftermarket intake and test pipe but would they still do the service for me or should i put everything back to stock? when is this going to end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnoytypeR »</TD></TR><TR><TD CLASS="quote">ok so im running on an aftermarket intake and test pipe but would they still do the service for me or should i put everything back to stock? when is this going to end? </TD></TR></TABLE>
Probably would want to put it back to stock and I dont think there is a time limit on the free service.
Running a test pipe completely defeats the purpose of what honda is trying to do.
I work at a honda dealership, and i also got a new cat out of the deal.
SHOCK5
Nov 29, 2006 09:40 AM
