CIVIC SI EF Cluster Problem HELLLPPP....!
Old Mar 20, 2008 | 02:08 PM
1kreationz401's Avatar
Default CIVIC SI EF Cluster Problem HELLLPPP....!
Hey Honda-tech, this is weird but, my cluster just stoped working on meeh and i cant seem to find out whats the problem, it was working perfectly until 2 days ago. i have check out all the fuses on engine bay and fuse box under dash, no fuse are bad.
Description of how its not working:
-RPM meter is not working
-Gas meter is not working
-Temp meter is not working
-Check light doesnt light on ACC
-Seatbelt doesn light on ACC
-Timer doesnt show only if i press on to it
-Turn signals dont work
Whats Working:
-Cluster backlights work
-Turn signals go on only if i press the emergency button
Clueless now so please let me know if anyone has gone through with problem before.
Old Mar 20, 2008 | 02:37 PM
Default Re: CIVIC SI EF Cluster Problem HELLLPPP....! (1kreationz401)
ttt
Old Mar 21, 2008 | 08:48 AM
someone help me out please....lol
Old Mar 21, 2008 | 08:55 AM
doublethink's Avatar
if you want to check it wire by wire you need a helms manual.
sounds like you may have lost a ground or a 12 volt, or the piece is internally shorted, aka broken.
another way you could get the wire colors would be to read the FAQ stickied at the top of this thread and find threads about cluster swapping, since they often list the oem color scheme.
use a digital multimeter for all tests, you can get one at any sears for $20. make sure it has continuity testing for ground.
if all of which i just said is incomprehensible to you, a trusted mechanic should be your next step.
good luck.
Old Mar 21, 2008 | 01:54 PM
Default Re: CIVIC SI EF Cluster Problem HELLLPPP....! (doublethink)
it has power for the brake light and back lights for the cluster
but i tried switch bulbs to check light are
still nuthing....im thinking my cluster might had gone bad on me...!
Old Dec 23, 2019 | 06:55 PM
Tinozaurio_3's Avatar
Hey did you ever figure out the problem ? I’m having the same issue
Old Dec 24, 2019 | 05:02 AM
scelestus's Avatar
After 11 years, it's doubtful that OP has any memory of this issue - they also haven't been active since 2013. Go through the suggestions posted by doublethink, then start a new thread linking to this one with more info of your specific issues.
K2e2vin
Jan 15, 2008 04:54 PM
bresk8r87
Oct 17, 2007 07:47 AM
93WhiteHatch
Apr 29, 2006 05:58 PM
Civicvtihatch
Sep 16, 2004 10:28 AM
nxstrikerxn
Jul 9, 2004 08:00 PM
