Grinding noise from the right wheel (psg side) when turning hard to right
Old Mar 20, 2008 | 01:36 PM
vigorhy's Avatar
Default Grinding noise from the right wheel (psg side) when turning hard to right
My car started to have some grinding noise from the psg side wheel when I turn to right.
It has no such noise when driving straight or turning to left.
I checked CV boot, and it is fine no broken. Can any one give any advice?
Thanks a lot!
Old Mar 20, 2008 | 02:04 PM
Perfectionist's Avatar
Default Re: Grinding noise from the right wheel (psg side) when turning hard to right (vigorhy)
CV joints would make a knocking noise. Try to lightly apply the brake when turning right. If the noise changes or goes away, your brake pads may be shifting or just plain worn out. A wheel bearing would make more of a rumbling noise in my experience, but I wouldn't rule it out.
Old Mar 20, 2008 | 03:28 PM
JDM_Acccord's Avatar
yeah, the cv axle would be more of a knocking or a loud ticking noise...
Old Mar 20, 2008 | 03:54 PM
vigorhy's Avatar
Thanks buddy!
I tried to apply brake when turning, but nothing changed.
Actually, it is very weird. if the turning is not very hard or speed is slow, there is no noise coming out, but when weight loads to left side over some point, that grinding noise occurs.
Could that be the problem of the wheel bearing?
Dackonn
Suspension & Brakes
37
Mar 2, 2025 02:16 PM
Forrest04
Honda CR-V & Element
Apr 16, 2014 11:50 AM
Lude Acts
Jan 24, 2008 05:25 AM
erikiksaz1
Sep 13, 2004 06:00 PM
juicedricer
Mar 6, 2003 05:39 PM
