Hondata S300
Old Mar 20, 2008 | 12:18 PM
95exdsmkilla's Avatar
Default Hondata S300
Just quick question to all the Hondata s300 users.
We just did quick dyno tune, but my fuel map and timing map does not respond. Other options still respond. Do I always have to get new software from hondata or can I use old version?
Old Mar 20, 2008 | 12:36 PM
havok hybrid's Avatar
Default Re: Hondata S300 (95exdsmkilla)
Make sure you have REAL TIME update turned on .. its under the a menu at the top.. that will allow see what is going on Live..
I dont know if that helps..
Old Mar 20, 2008 | 12:57 PM
MrParks's Avatar
update the software. you should anyways, they came out with the new boost control feature.
boost by gear/by rpm heard some geally good results !
hondata
Old Mar 20, 2008 | 01:20 PM
Default Re: Hondata S300 (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you have REAL TIME update turned on .. its under the a menu at the top.. that will allow see what is going on Live..
I dont know if that helps.. </TD></TR></TABLE>
Yea, we have tried that already. Can hodata go bad by it self??? it seems like the fuel/timing map does not want to respond at all.......
nothing is burnt on hondata it self neither
Old Mar 20, 2008 | 03:43 PM
MrParks's Avatar
i had the situation happen to me one time. you have to update your software and usb driver. it worked for me, some times things can happen when you unplug it during a upload or low battery, or a sudden surge in power somewhere. becareful to keep the ecu away from any ignition boxes as well.
Old Mar 21, 2008 | 10:41 AM
Spunkster's Avatar
First update you software. Second make sure you don't have secondary tables checked. If you do and you make changes to them you will not see the changes take effect because you are editing the wrong tables.
Old Mar 21, 2008 | 12:42 PM
Default Re: Hondata S300 (MrParks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks &raquo;</TD></TR><TR><TD CLASS="quote">i had the situation happen to me one time. you have to update your software and usb driver. it worked for me, some times things can happen when you unplug it during a upload or low battery, or a sudden surge in power somewhere. becareful to keep the ecu away from any ignition boxes as well. </TD></TR></TABLE>
Yes, we did all that. Now it have worse problem. Whenever I datalog my display on hondata s300. All of the sudden Injector duty cycle goest to 0.00 and car just shuts offf. Checked all the grounds, checked power on injectors, still does not work on fuel/timing map (but two step, boost control, fuel trim all works), checked dizzy, checked msd and main relay.... but no answer yet. This car is giving us real hard time atm lol. Thank you everyone. Any other suggestion?
BTW- No check engine light.
Old Mar 23, 2008 | 12:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exdsmkilla &raquo;</TD></TR><TR><TD CLASS="quote">
BTW- No check engine light. </TD></TR></TABLE>
Have you tried a whole new tune ? As a test and see if u can mode the fuel/timing ... maybe its just your file?
Just a thought ?
eg:R
Dec 19, 2007 10:18 AM
slammed_93_hatch
Mar 5, 2006 06:39 PM
superls92
Dec 24, 2005 04:10 PM
WhiteHype08
Jan 14, 2004 10:07 AM
crx1856
May 14, 2003 10:14 PM
