Hood wont shut tight???
Old Mar 20, 2008 | 09:30 AM
02_Si_FTW's Avatar
Default Hood wont shut tight???
Solution: THANKS TO eloist2
loosen the 2 10mm bolts holding your hood latch in place.
Once loosened, push the latch as far as it will go down towards the ground. Now re-tighten the bolts.
next, twist your rubber stoppers all the way down as well. See if this helps.
Hey guys, Ive been tweaking with it but my hood wont seem to shut tight.. it locks and everything but theres about a 1/4 gap between the hood and where its supposed to be. You can kind of see it in this pic.. Any ideas on what the issue could be?
<U></U> <U></U>
Modified by 02_Si_FTW at 10:24 AM 3/27/2008
Old Mar 20, 2008 | 09:51 AM
05rsxS's Avatar
Default Re: Hood wont shut tight??? (02_Si_FTW)
You tweaked with the hood latch already?
Old Mar 20, 2008 | 10:24 AM
02_Si_FTW's Avatar
Default Re: Hood wont shut tight??? (05rsxS)
i havent.. you think that may be it? i didnt wanna mess it up worse
Old Mar 20, 2008 | 11:30 AM
SkankyEJ7's Avatar
WHat about the rubber stoppers? Have you messed with those any?
Old Mar 20, 2008 | 11:44 AM
05rsxS's Avatar
That could possibly be the problem, just adjust your hood latch and see if it helps.
Old Mar 20, 2008 | 12:29 PM
Tyte-S's Avatar
If it's sitting high(which it looks like it is), then you most likely need to lower the rubber stoppers. Just twist them to you get them to the desired height.
Old Mar 20, 2008 | 11:43 PM
02_Si_FTW's Avatar
Default Re: Hood wont shut tight??? (Tyte-S)
im sitting 2.25 front / 2.0 back now on skunk 2 springs.. the pic is old. Riding on 16" slips, but does ride height affect the hoods stance? rubber stoppers eh.. have to see if i can find some.. im going to tweak with the latch a little first.
Old Mar 21, 2008 | 06:13 AM
SkankyEJ7's Avatar
No, that has nothing to do with hood fitment.
Old Mar 21, 2008 | 12:10 PM
dc5Aspec'd's Avatar
Have you jacked your car up lately? If you have, you probably didn't jack it up on the correct place. You have you push down on the bar/brace that holds the latch to get it back in the right place.
Old Mar 21, 2008 | 11:05 PM
Master23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05rsxS &raquo;</TD></TR><TR><TD CLASS="quote">You tweaked with the hood latch already?</TD></TR></TABLE>
How do you adjust the hood latch?
Old Mar 23, 2008 | 12:29 PM
JDM_Matter's Avatar
Default Re: Hood wont shut tight??? (Master23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master23 &raquo;</TD></TR><TR><TD CLASS="quote">
How do you adjust the hood latch? </TD></TR></TABLE>
Same here..........
Old Mar 24, 2008 | 08:01 AM
Danny BAGDAD's Avatar
Default Re: Hood wont shut tight??? (dc5Aspec'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5Aspec’d &raquo;</TD></TR><TR><TD CLASS="quote">Have you jacked your car up lately? If you have, you probably didn't jack it up on the correct place. You have you push down on the bar/brace that holds the latch to get it back in the right place. </TD></TR></TABLE>
True, a bent radiator support will cause this
Old Mar 27, 2008 | 07:18 AM
02_Si_FTW's Avatar
Same.. i tryed and my noob self couldnt figure out how to adjust the hood latch
Old Mar 27, 2008 | 08:26 AM
eloist2's Avatar
lossen the 2 10mm bolts holding your hood latch in place.
This a common problem with ep3's...it happened to mine and I have seen it happen to many others.
Old Mar 27, 2008 | 09:03 AM
02_Si_FTW's Avatar
Default Re: (eloist2)
thanks a lot eloist
Lightsped
Aug 14, 2008 10:02 AM
stevew84
May 30, 2008 08:38 AM
Soda Popinski
Oct 19, 2005 06:34 PM
kidd_drastic
Oct 12, 2005 12:55 AM
Digitalcivic
May 29, 2002 06:08 PM
