small light fuse blown...sum1 plez help
Old Mar 20, 2008 | 07:52 AM
jdmEF8racer's Avatar
Default small light fuse blown...sum1 plez help
b4 any1 has any smart *** comments on how i should search i already did and fount nothing...i have a 96 prelude with a blown 20 amp small light fuse...one night i go out for a lil drive and when i go 2 turn on my lights i hear a pop...i notice my gauge lights, climate control lights, tail lights ( but brake lights ), license plate lights, and bumper lights all dont work...first thing i do is replace the blown fuse with a bigger...thinkin maybe my 10k HIDs maybe drained a lil power from everything eles...but i a friend said that wouldn't make a difference but i tried any way...but that fuse blew as well...so i asked one of my friends that works at a honda dealership and he told me a lot of prelude and accords have this problem...it could either be the fuse box or jus a simple short in the circuit...well i tell myself that it cant be the fuse box because cuz then everything wouldnt work, so most likely its a short...does any1 out there no how to check for a short in this circuit or has any1 been in this situation b4...i need help ASAP cuz inspection month is cumin up and there is no way i will pass thanx
87 CRX w/ D16 Vtec - sold
90 CRX HF w/ JDM GSR - totaled
91 CRX Si ( JDM BEAST ) w/ B16 - stolen....gone but not forgotten
96 Prelude w/ P.O.S F22 - h23 wanted
Old Mar 20, 2008 | 11:48 AM
JasonST's Avatar
Default Re: small light fuse blown...sum1 plez help (jdmEF8racer)
So it's only when u turn your lights (headlights on)? high beams and low beams? Since it's only when you turn your lights on that means that a power wire(positive) is shorting to ground somewhere after the light switch. It would really help if you had a circuit diagram for your lights.
Old Mar 20, 2008 | 01:11 PM
socialistic's Avatar
Check the wiring for your HID kit. I bet my bottom dollar that's where the problem is. Remove that kit(ballasts and all) temporarily...then try turning your lights on, and tell us if that fuse blows again.
Could be a bad ballast, ballasts drawing too much power, or a wire shorting out. My best guess is you melted an HID-related wire and it's contacting something it shouldn't causing the light fuse to blow...I've seen this happy MANY times, that's why I don't run HID on anything I drive.
Old Mar 21, 2008 | 07:49 PM
John427's Avatar
I have the same problem (small light fuse blows) different model & year - mine Accord 1992. Just started happening - vehicle at repair shop all week, they diagnoised bad multi-function (headlight) switch now they say that's not it - maybe in dash - that's scary and $$$$ - anyone else have this issue?
Old Mar 22, 2008 | 02:58 PM
slamdlude's Avatar
Default Re: small light fuse blown...sum1 plez help (John427)
You could always put a paperclip in the spot where the fuse is supposed to go, turn the lights on and look for burning wires/smoke. Just make sure you can take it out quickly once you find the problem.
Old Mar 25, 2008 | 09:14 AM
Default Re: (socialistic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socialistic &raquo;</TD></TR><TR><TD CLASS="quote">Check the wiring for your HID kit. I bet my bottom dollar that's where the problem is. Remove that kit(ballasts and all) temporarily...then try turning your lights on, and tell us if that fuse blows again.</TD></TR></TABLE>
idk if that is it...cuz i had my HID's in for almost a year when this happened...i mean ill check it out but idk...and it doesnt matter if it high beam or low...when i turn my head lights on...thatz tha only thing that cumz on...inside or outside the car..but quick question...if i had a bad connection at my positive wire on my battery can that **** with things...cuz i was drinvin tha other day and i hit a bumb and my radio turned off..and i noticed my positive wire was a lil loose...didnt check if it helped tho...(ran out of fuses) lol
Old Mar 5, 2010 | 08:37 AM
rob240sx's Avatar
did this guy ever find the problem, i'm having the same issue
Old Mar 19, 2010 | 07:51 PM
NUBBS2385's Avatar
TRIAL USER
Icon3 Re: small light fuse blown...sum1 plez help
if anyone with this issue of the small light fuse, and you have an aftermarket deck/stereo/dvd playe, any of these just double check that the illumination wire off the harness isnt being grounded out. i just learned this today. hope this helps anyone. please let me know if this works for you. nubbs2385.webs.com
Old Sep 2, 2011 | 09:48 PM
nismofong's Avatar
Icon6 Re: small light fuse blown...sum1 plez help
OMG! never thought about that, just put in this used dvd deck that already has Ilumination wire connected to parking brake ground on its own honda harness. Will cut it in the morning, i bet my bottom dollar thats the case.
MCHAccordLX
Jun 26, 2016 10:53 AM
EcoWhale
Jul 17, 2015 12:56 PM
nick1989
Aug 27, 2007 01:41 PM
gsrcivic619
Mar 23, 2006 10:53 AM
dizzyroc88
Jan 26, 2004 07:43 PM
