cluster Light
Old Mar 20, 2008 | 12:45 AM
Kid_SiR's Avatar
Default cluster Light
hey i was driving one night an my cluster lights went out but everything else works like the turn signal comes on the cluster check engine light but not the other lights too see the cluster i changed the fuse an nothing is there a relay that i have too change
Old Mar 20, 2008 | 12:00 PM
xalents23's Avatar
Default Re: cluster Light (Kid_SiR)
Check your cluster bulbs.
Old Mar 21, 2008 | 12:53 PM
Kid_SiR's Avatar
i check that but its not only my cluster its the climate control lights aswell
Old Mar 21, 2008 | 04:55 PM
grog's Avatar
Default Re: (Kid_SiR)
Check your grounds, make sure the plug is tight. Pull the cluster out and inspect the curcuit board on the back side for burns or abnormalities.
if all that doesnt help get a wiring diagram and multimeter and check the wiring.
Old Mar 21, 2008 | 06:11 PM
hatchaddict's Avatar
Change your dimmer switch
Old Mar 21, 2008 | 10:42 PM
Kid_SiR's Avatar
ok well i check out my cluster i even switch it out for another one dosent work every other light works but the back up lights on the cluster
worx
Nov 7, 2012 06:10 AM
2000-em1
Nov 16, 2011 10:26 AM
kcrxxx
Apr 2, 2008 08:13 PM
fwdftw
Mar 28, 2004 07:12 PM
jdmjeff
16
Dec 15, 2003 08:31 PM
